07-26-2019 | #11 |
Re: Cam Sensor Questions
I am at work and can't find the post but there is a vendor that sells the sensors as I have one
It needs to be modified for it to work as noted in prior post. I can find the vendor later.
07-26-2019 | #12 |
If you look around these links you will find the vendor if not I can look later.
http://www.zr1.net/forum/showthread.php?t=30588
07-26-2019 | #13 |
The sensor.
https://www.diyautotune.com/product/...sition-sensor/ Pages 3 through 6 are useful. http://www.zr1.net/forum/showthread.php?t=28584 I have a spare just for the heck of it.
07-27-2019 | #14 |
Did you do this with a 90 or a 91 for testing? It took all day to take the old sensor out and another day to get it in. The ASR is right in the way and I have large hands. It is done.
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
07-27-2019 | #15 |
Wow, that ASR must be a huge PIA.... I was done on my 90 in about 15 minutes, remove and replaced... Did it from under the car.
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
07-28-2019 | #16 |
Yes, it was a huge pain. I have a pint of oil on my garage floor from swapping out the sensor. The ASR has a lot of hoses under it that was constantly in the way. Don’t want to do that again anytime soon.
07-30-2019 | #17 |
Well, replaced the cam sensor and worked on my FX3 right rear timeout. Started up the car and it would barely run. WTF! Shut it down and pulled the code 31. So now I’m going to have to check around the ASR to see if it got put back correctly and check the connection on the cam sensor. It sounded like I only had 4 cylinders.
07-31-2019 | #18 |
Phil’s inbox is full so I’m posting here. Got the sensor out and added a washer to it to increase the air gap on the sensor. Didn’t work. Ran a little better but still messed up. Tomorrow, I’m going to add another washer to try to increase the air gap a little more. The good news is that I can take apart the ASR and A.I.R. stuff in about 5 minutes. Had no idea that this could happen.
