02-24-2019 | #11 |
Re: Amazon engine oil vs the world
From Marc’s analysis:
http://www.zr1specialist.com/HAT%20W...5%20Engine.pdf Sent from my iPhone using ZR-1 Net Registry
02-24-2019 | #12 |
Marc’s article shows phosphate of 1000 and zinc of 1100 for Mobile 1 High Mileage. I noticed the latest product data from Mobile 1 High Mileage phosphate and zinc content dropped to 800 and 900 respectively.
02-24-2019 | #13 |
So the Mobile 1 is now 67% of the phosphorus SG requirement and 69% of the Zinc SG requirements. Although Marc’s original analysis at the time was valid, his point is that Mobile 1 has been reducing the required amount of additives over time. You may not ever notice an impact on your engine, cam shaft chains or catalytic converters , but way chance it. “The bitterness of poor quality remains long after the sweetness of low price is forgotten.”
Your choice. JMHO Sent from my iPhone using ZR-1 Net Registry
02-24-2019 | #14 |
The API SN Pus of the Amazon oil means it’s protection against low speed pre-ignition for Turbocharged and direct injection gasoline powered vehicles.
02-24-2019 | #15 |
Warren Distribution makes the oil for Amazon and Walmart. Seems to be the same oil.
The Amazon oil beat the Mobile 1 in the cold weather test. It would be nice to know the zinc content.
02-24-2019 | #16 |
This data is from 2014 and helped me purchase my oil over the past few years while at the local AutoZone or such.
https://oppositelock.kinja.com/oil-a...ata-1667481179 http://www.bestsyntheticoilfilter.co...complete-list/ I cannot find anything today from 2019 or 2018.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* Last edited by Karl; 02-24-2019 at 07:04 PM. |
02-24-2019 | #17 |
I will faithfully use Mobile-1 in everything that I own. (Even my lawn mower gets it...lol)
Trust me, I’ve seen all the tests and I’ve also seen real world LS engines with 300,000 very hard miles, that still had the original factory cross hatching in the cylinders and bearing coatings in as new condition after I tore them down while using only Mobil-1.... I’d rather not delve into the chemical properties of all the oils and what labels say.... I trust real world results. And guys, remember....When we’re talking about Zinc content, we are referring to PPM (parts per million) that’s like one small drop in a 10 gallon tank of oil.... just putting things in to perspective. Sent from my iPhone using ZR-1 Net Registry Last edited by Ls7/Ls9 Test Engineer; 02-24-2019 at 08:38 PM. |
02-24-2019 | #18 |
Well with Mobile 1 high-mileage changing its formula it may finally be time to start using Amsoil Z-Rod 10w30. $143 for a case of 12 qts plus shipping.Ouch!
Gary 90-1572 |
02-25-2019 | #19 |
Specifications:
Description AMZN BCS 5W30 DX HM SYNSN+6/1Q Inspection Information Typical Value Gravity, °API 34.93 Specific Gravity @ 60°F (15.6°C) 0.8502 Flash Point, °C 227 Flash Point, °F 441 Viscosity @ 40°C, cSt 62.09 Viscosity @ 100°C, cSt 10.91 Viscosity Index 169 Pour Point, °C (°F) -45°C (-49°F) Cold Cranking Simulator at (°C), cP 4400 (-30) High Temperature / High Shear Vis at 100°C, cP 6.9 High Temperature / High Shear Vis at 150°C, cP 3.2 Noack Volatility, % loss 12 Color 3 Zinc, wt. % 0.085 Phosphorus, wt. % 0.076 Calcium, wt. % 0.135 Sulfur, wt. % 0.3 Magnesium, wt. % 0.059 Boron, wt. % 0.023 Molybdenum, wt. % 0.0079 Sulfated Ash, wt. % 0.9 Nitrogen, wt. % 0.104 Pumping Viscosity at (°C), cP 15,000 (-35) Shear Stability, Final Viscosity in cSt 9.4 High Temperature Foaming, static foam 15/0 TBN, mgKOH/g 7.9"
02-25-2019 | #20 | |
Also, implying, as an engineer, that because ppm for an additive is very small, and I guess implying that it's somehow not important...is misleading. In this day and age, those additives (in ppm) are the only things differentiating one companies oil from another. The old adage goes: - What do you call a bucket of p*ss with a drop of water in it? A bucket of p*ss. - What do you call a bucket of water with a drop of p*ss in it? A bucket of p*ss. Sometimes a small amount is important. |
