01-27-2019 | #11 |
Re: Uneven brake pad wear
I started the back brakes. Interesting that these pads show a taper too, even though the rear is single piston. It’s just barely visible.
The top in this picture is the leading edge. These pads look just destroyed. Anyone thinking about buying Raybestes pads. I suggest don’t. Sent from my iPhone using Tapatalk
1990 Red/Saddle #1521 |
01-27-2019 | #12 |
Here’s a shot of my front wheel the day after.
01-27-2019 | #13 |
Nice Photos and thanks for Posting
That is MOST Interesting that both Pistons In the Stock Dual Piston Front Capliper are the Same Size That would then explain the issue as you found in the BMW link related to the Moment requiring a larger Following Piston as a Remedy. I checked my C5 Z06 Calipers and the Following Piston is Larger Diameter WOW Another Reason to Convert to C5 Z06 Calipers. Post 233 - Installation of Wilwood Rotors and C4 to C5-Z06 Conversion
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-27-2019 at 09:52 PM. |
