01-11-2019 | #11 |
Re: Rear Mounted Oil Cooler
That won't happen. thermostat valve was engineered with bypass to insure the oil cooler system is always charged with oil.
01-12-2019 | #12 |
Seems to me like the worst that could happen then is that the cooler doesn't work very well do to pressure drop.... so I'd need to figure out what the drop is from adding about 20ft of hose to the system
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
01-13-2019 | #13 |
I'd be worried about potential damage from road debris being kicked up from the front tires as well as the low pressure area under the engine.
And damage from speed bumps, pot holes etc. Our Zee's ride low, low, low, anything hanging from the bottom is going to be in harms way. Just my $.02 'Crabs
01-13-2019 | #14 | |
Proper undercar routing would certainly be a concern. I would run braided hose and protect it in high exposure areas. I was eyeballing the covered channel inside of the rocker moldings for most of the run, might be able to get two hoses through there.
01-14-2019 | #15 |
I run an Accusump to the rear of the ‘88 car. A single braided line barely fits under the rocker. The Accusump does not need a high pressure area to keep it cool like a cooler would.
What Crabs pointed out is that the area under the car is a low pressure area, unlike the stock location in a high pressure area. The area under the car in the rear may not provide sufficient airflow for the oil cooler to work - racers have used the rear area to cool gearbox fluid, but with puller fans directly mounted to the cooler. Sent from my iPhone using ZR-1 Net Registry
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 |
01-14-2019 | #16 |
I've recently moved my battery to the box behind the passenger seat and used the rocker areas to run the positive and negative cable; negative along passenger side outside the panel alongside the fuel lines and positive inside the rocker panel with factory wiring. Note much room, especially for the size hose needed. Though I haven't run my ZR-1 on the track yet, I've plenty of experience with a brand "P" air cooled race car that lives on cooled oil run from the rear engine to the front. The lines are huge, 30mm to 50mm. No such room on the bottom of a stock ZR-1 for lines this large. Other ways to remove front end weight are a better option.
01-15-2019 | #17 | |
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 01-15-2019 at 01:06 PM. |
05-27-2019 | #18 |
Well I'm going to be working on the belt tensioner and also replacing the a/c condenser so I've been kicking this around again. I remember that some of the turbo charged cars either Callaway of LPE I think utilized the inside of the frame rails to run some plumbing from the rear to the front. It occurred to me that perhaps I could route oil cooler lines through the frame rails themselves. Anyone know if there are bulkheads or other obstructions inside the frame rails? If not it would seem possible to snake a line through there.
05-28-2019 | #19 |
I'm not sure that moving a couple pounds from the front to the rear, only to add 3-4 lbs total to the car will be worth it.
05-28-2019 | #20 |
How much more oil would u need to fill the system?
