Old 10-20-2018   #11
BurnRubber
BurnRubber's Avatar
Default Re: ZR-1 Parts:Name Your Part & Price
Originally Posted by phrogs View Post
Hey send them my way
I will buy a good used ECM for $1000. Come on guys. Cough one up for me.
91 Corvette ZR-1 #1346
BurnRubber is offline   Reply With Quote
Old 10-20-2018   #12
91vettezr1
91vettezr1's Avatar
Originally Posted by BurnRubber View Post
I need a good used Ecm. $650
i know marc haibec is rebuilding these units zr1specialist.com
91vettezr1 is offline   Reply With Quote
Old 10-20-2018   #13
BurnRubber
BurnRubber's Avatar
Not mine. I already sent it to him.
Old 10-21-2018   #14
garyhugo
garyhugo's Avatar
Pete if you can get the wheel speed sensors out in good working condition I will take all four.
Gary
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 10-21-2018   #15
George Maz
-VSS vehicle speed sensor
-Reverse switch plug
...both are small parts from the transmission if you can spare them.
-Will take 4:10 correction gears, blue & white, if present.
-plastic grommet, for drain at fuel fill boot.
-foam doughnuts, from rear hatch pistons.
-rubber grommets, from rear plastic decklid.
-DERM (if no airbag deployment)...would like to give it to member "WVZR1".
-driver side PCV tubes aluminum hardlines tabs intact.
- Horns ...honk honk...lol.
Probably more stuff too, maybe easier if I just take pictures of what I need.
Sent from my SM-N920V using ZR-1 Net Registry mobile app
George Maz is offline   Reply With Quote
Old 10-22-2018   #16
S.hafsmo
S.hafsmo's Avatar
Do you have the braces for the rear fender/wheel well (upper+lower)?
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 10-22-2018   #17
mhobtr
Check your PM's.
mhobtr is offline   Reply With Quote
Old 10-22-2018   #18
mhobtr
If you can get the antenna grommet off without tearing it up, I will buy it.
Old 10-22-2018   #19
Flyman 27
Flyman 27's Avatar
Picked up my parts Sunday, thanks Pete!
His car still has both rear quarters intact if anyone needs them, they are in very good condition, but you have to be quick, the car will soon be gone.
He also has a steering column with wheel & air bag in good condition. BTW, how much did you want for it?
[SIGPIC][/SIGPIC]
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 10-22-2018   #20
It was removed without tearing it, I know as I was there. But are they different then a narrow body car? Meaning has anyone one here confirmed it?
