Old 10-09-2018   #11
Default Re: Startup Squeak
Bob is correct, rebuild is now the only option
Old 10-09-2018   #12
So u r saying it NEEDS to be rebuilt, correct?
Old 10-09-2018   #13
I am saying that if it is the problem and needs to be fixed, then rebuild is the only option other than a used part if you can find one
Old 10-09-2018   #14
If you want to get rid of the squeak yes.
Old 10-09-2018   #15
I guess I'll get Marc's opinion. As I described, the squeak only manifests itself at first start, then fades to inaudible w warmup. It doesn't come back until the motor gets stone cold overnight. I do have a spare which is the one I swapped out thinking this one was newer. However, nothing wrong w old one, just a preventative measure.
Old 10-09-2018   #16
tpepmeie
This may be a silly question, but how old is the belt and are you certain it is the right size? Try the easy stuff first.
Old 10-09-2018   #17
Todd,
Thanks for chiming in. Belt was changed last year when Pete rehabbed the motor when he found the busted compression ring on #7. Its the tensioner because slight pressure on the tensioner during warm up, as Phil suggested, eliminated the squeak by restricting travel of the tensioner. Remove pressure, squeak is back.
Old 10-09-2018   #18
jss06c6
Dom,
Do you need a wheel? I've got one spare that I can send you. Mine is still holding on. When it goes out, I can find another..
Steve
Old 10-09-2018   #19
Originally Posted by jss06c6 View Post
Dom,
Steve
Steve,
Thx but not necessary. I have a spare tensioner. Just need to swap pulley from the one on there. If I need one, I’ll drop it off to Marc.
Old 10-09-2018   #20
jss06c6
Steve,
Ok..
