Old 10-04-2018   #11
jpalmer1717
Default Re: Courtesy lights not working...
Yes, top of dash light sensor.
jpalmer1717 is offline   Reply With Quote
Old 10-04-2018   #12
I don'e think that has an effect on the courtesy lights.. only Canadian cars had that sensor
Old 10-04-2018   #13
jpalmer1717
I was looking at the wrong light sensor. I now see the tiny sensor directly in front of the driver on the dash. How can I check to see if this sensor is my problem?
Old 10-04-2018   #14
gtcollins@maxnet.co.nz
When it's outside in the light with the key on cover the sensor the dash will dim
Sent from my SM-G930F using ZR-1 Net Registry mobile app
Old 10-04-2018   #15
jpalmer1717
There must be another way to check this sensor rather than assume it's the problem. No lights come on with the sensor in complete darkness. Can I bypass the sensor without harming anything to see if the lights come on?
Old 10-04-2018   #16
I don't think that it is the sensor..
Do you own a Factory service Manual for the Corvette?
I still say test things out through the CCM and also check the Courtesy Light relay
Old 10-04-2018   #17
jpalmer1717
I do have the service manual... trying to make sense of it now. Do you know the location of the courtesy relay?
Old 10-04-2018   #18
If I am sitting in the drivers seat.. first relay to the right f the column, behind the hush panels
Old 10-04-2018   #19
jpalmer1717
I'd be all over replacing the relay if I knew what a hush panel was....
Old 10-04-2018   #20
jpalmer1717
So you're saying the courtesy relay is on the passenger side under the glovebox carpeted area?
