Old 09-23-2018   #11
lfalzarano
Default Re: Random tick/tap noise?
BTW - Marc H’s chip includes all the GM updates that cures the idle and stumble.
“If the octane is too low, and the engine detonates, the knock control system will reduce the spark advance for about one second. The driver would notice a one second sag in acceleration as power is reduced by about 20 hp for the one second period.” From Marc on a stumble I had with OLD gas!
Lou
Old 09-23-2018   #12
Tommio RS
Hmmmm interesting info about the Marc H chip there.
Can I just remove the DRM chip and still run the car as a "stock" tune?
I ask because on JDM cars like subaru's and nissan's you have a socket JUST for a tune. You cut or add a jumper in most ECU's and the car will run on your tune at that point. This is of coarse on older JDM cars.
The ZR-1 from what i can tell you pull the chip out then you need a "stock" chip in place of the tuned chip? I think i right in saying that?
And for this possible clutch issue.
How do you check if the dual mass flywheel is failing?
Is there an inspection port maybe?
From what i can hear at idle in my garage the bearings "sound" ok like pilot and throw out. The rest is unknown to me.
Any input is great!
Tommio RS is offline   Reply With Quote
Old 09-24-2018   #13
lfalzarano
Default Random tick/tap noise?
Tom,
I recommend you contact Marc about the chip installation and impact.
Lou
Old 09-24-2018   #14
Tommio RS
Cool beans.
Ill contact Marc about the chips and such.
Still trying to wrap my head around a possible flywheel issue.
Going to have to so more research i guess about that.
Old 09-25-2018   #15
QB93Z
QB93Z's Avatar
I will try to describe the "fly wheel" sound you asked about. The Dual Mass Flywheel has two separate rotating masses that have a dampening mechanism relative to each other.
For a healthy engine, the rotational pulsations are small enough that the flywheel makes no noise. At idle, with the transmission in neutral, when one injector is not passing fuel, it causes a rotational pulsation that can cause the flywheel dampening to over travel and make a ticking sound.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 10-04-2018   #16
Tommio RS
Hmm very interesting QB93Z.
That makes sense now!
Also! This possible high idle seems to be driving me kind of nuts! Lol
I have used a boro scope/ tiny snake camera to look under the intake manifold and such, and i dont see any vac. lines off that i can tell.
So my next step is im going to smoke leak check the intake manifold and such. If i see smoke coming out from under the intake manifold.....Im going to pull it.
Now if i don't see smoke from under the manifold. Im now leaning towards a leaking fuel injector or a none firing injector. Are the ZR-1 known for injector balancing issues or injector issues in general? My car did sit for 3 years before i got it.
I would think a leaking injector could very well make the car idle higher than normal or a vacuum leak would do the same also.
Thoughts?
1995 ZR-1 Black on Black
Old 10-05-2018   #17
QB93Z
QB93Z's Avatar
When you are driving, is the secondary system operating properly? That is, do you have strong acceleration at full throttle all the way to ~6000 rpm?
The high idle issue is most likely NOT related to an injector issue.
Old 10-23-2018   #18
Tommio RS
OK.
I have done a little more testing since last time.
I had the car hot and checked with the HVAC how accurate the tacho is.
Im reading a 32/33 about so 32X25 is 800. So i think my tacho is reading 150 to 200 RPMS to high. But the gauge does not look all the accurate form the get go! Sorry to say that. Will likely replace the PCV valves and MAP rubbers over the winter months now.
For the ticking noise after being hot/warm and such.
I swapped the plugs as with the AC 41602's and set there gap to .38
The plugs i removed were from what i could tell were the ORIGINAL PLUGS!!!!!
No joke! The gap i was seeing on some of the plugs was .80 plus!
So now doing the same drive.....Car does not tick! Im happy!
The only side effect from all this "diag" work is now i know i need some new tires! I can very easily spin the tires in 1st gear and chirp them fairly hard into 2nd gear. Again. I don't how how much power the car really has in it due to the tires. Also i have NO idea if this motor has been opened up before. The hardware all over the motor looks untouched to me so i would think not but you never know.
Thanks again.
Old 10-23-2018   #19
conesare2seconds
It’s nice when the solution is simple. Glad you found the problem.
Old 10-24-2018   #20
Originally Posted by Tommio RS View Post
OK.....The only side effect from all this "diag" work is now i know i need some new tires! I can very easily spin the tires in 1st gear and chirp them fairly hard into 2nd gear. Again. I don't how how much power the car really has in it due to the tires.....Tom
You haven't even BEGUN to have fun until you can chirp the tires in fourth gear!--Bob
