#11 | |
![]() ![]() ![]() Join Date: May 2007
#12 |
![]() Join Date: Sep 2012
Thanks for the replies. No 'Service ABS' light appears in the DIC on initial ignition switch on. The ABS unit behind the driver's seat does whir for a short while on ignition turn on. I know that there is a bulb in the 'Service ABS' location within the DIC as I took a picture of it some while ago when I had the DIC removed. What I do not know is whether that bulb works or has blown! I will check this out. Thanks again.
Richard 1990, numbers 1821 and 2391 1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's 2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch. |
#13 |
The 'ABS Active' indication was first implemented in '91. It will turn on for a second during the pump self test when the car goes to about 8 mph following key on. In '91 a relay was added to drive the light. The light can be activated on a '90 if you copy the wiring and add the relay as shown in the '91 service manual. I did it once to diagnose a '90 car with big brakes and was locking the wheels too much. The solution to the problem was to change to a brake pad with less friction.
#14 |
Thanks Marc - Really interesting and informative information, especially to those of us with 1990 ZR-1's.
