#11 | |
How do you know you are NOT getting 405 HP (specifically)? How did you solve the LTPWS service light (Specifically)? |
#12 | |
About the LTPWS it would set it self only when I would drive under 25 mph for about 1 mile. That happen's when I drive on the county road to the state HWY. There are a few small rocks on the county road surface. I drive slow to protect the paint....I could not clear the trouble code with the grounding of A & B. But it doesn't show up on the DIC unless I drive under 25 for about one mile which by the GM repair manual states is normal. The strange thing is it never would throw a LTPWS code until I had to replace a wheel sensor some time back. Since then I have replaced that wheel sensor twice with new sensors same part number. Under the same driving conditions it now throws a code. I hope this makes since. Thanks for your help..Ellis |
#13 |
Thank you I wasn't sure. It has been a long time since I have had full power work. I have had this car 25 years but don't get it out much. I would like to get it working so I can move on to another car project.
#14 |
![]() Join Date: Aug 2004
My first 91 was the same way. I could tell it lost power. So I installed new injectors as it really needed them. I also did fuel filter and both in tank fuel pumps along with a new sock. Still not quite full power. With Marks Haibecks help we determined it was the round fuel pressure regulator that sits behind the plenum. Once replaced it ran like a scalded monkey. I believe it was leaking vacuum at the regulator. Easy fix. Probably didn't need to spend the money for fuel pumps in my case.
91 Turquoise Metallic Haibeck 525 #0134 |
#15 | |
![]() This is what I would do ![]() Post 281 - The Improved LT5 Fuel Pressure Regulator Post 282 - Changing Out Improved Fuel Pressure Regulator (IFPR) Post 283 - Phil's (Jagdpanzer) Fuel Pressure Regulator Solution
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-01-2018 at 01:48 PM. |
#16 |
![]() Join Date: Oct 2016
#17 |
![]() Join Date: Nov 2011
On the 90's, the power key stays where you put it. Later years are momentary switches and need to be set to "full power" every start up. The 90's have a "full engine power" light in the DIC. I didn't realize later years didn't.
#18 |
![]() Join Date: Feb 2018
I think it's important to stress that the 90 power key actually closes a circuit for the system to operate. In my car, the Full Power light was flickering intermittently, and the key switch was the culprit. I was able to fix it by dissasembling the tumbler and cleaning and shaping the contacts. As for the rest of the system, I also found a vacuum leak in the solenoid between the vacuum canister and the actuators. The solenoid spring and plunger were rusted pretty badly.
Sent from my moto g(6) play using ZR-1 Net Registry mobile app
-Stephen 1990 #2288 |
#19 | |
#20 | |
At this point I am thinking power key not working or maybe a bad sensor. Something somewhere not making contact. Any one know where I can buy a new fuel pump gasket, Between pump and gas tank. OEM type. Mine looks ok but would like to have a new one. Thanks to all of you who have responded. ![]() Last edited by Route 66; 09-03-2018 at 11:06 AM. |
