Old 08-17-2018   #11
onethumb
Default Re: Increasing intake air flow on a LT5
Originally Posted by lfalzarano View Post
Buy a SLP claw intake and save your original air filter assembly for originality in the future.
Lou
It seems that the issue at hand is not the intake itself, but the path of air to the intake. I've always thought that these sort of intakes just suck hot engine compartment air it rather than cooler outside air, thus negating any benefit from having a larger filter area and less resistance.
Or am I reading this wrong?
Stacy Faught - 1978 Alfa Romeo Alfetta, 1983 Alfa Romeo GTV6 (3.5L), 1991 Corvette ZR1, 2018 Alfa Romeo Giulia Quadrifoglio
onethumb is offline   Reply With Quote
Old 08-17-2018   #12
aafc
aafc's Avatar
Ok i have been playing with 3 types of air intake systems.
The first one was the A/O Forced Air system,but the inlet to the hose is almost
cut in 1/3 size.
Number two. By using the hole made by the forced air system i made a scoop up to an open air filter lid.
Now my last one is a copy of the "PRO STOCK" system used by NHRA Pro
stock class. I made a tube out of alu hand formed to the stock air bridge(with reinforced insert ) and ready a 4 in 90 deg PVC fitting to witch i connected a cone shaped filter mounted inside the front bumper.
I still have to run tests to see if i have enough air to the motor.
http://www.zr1.net/forum/picture.php...pictureid=3793
http://www.zr1.net/forum/picture.php...pictureid=3789
http://www.zr1.net/forum/picture.php...pictureid=3792
This may not be good for most people,but if you cut a hole into front of your
car. You can try anything.
1990 #2546 white/black
one of a few auto 4l8OE eq ZR-1's
thanks
aafc is offline   Reply With Quote
Old 08-17-2018   #13
Ccmano
Ccmano's Avatar
I had Vararam’s on both of my C6’s and the affect on engine power was noticeable. My 08’ LS3 achieved 400rwhp with simply the Vararam and a canned tune.
That said I do not believe similar gains can be achieved on an LT5. The air filter system is simply not that restrictive. I use a K&N with an open lid and I remove the water barrier below the filter housing which allows more direct airflow. Still I doubt it makes a big diffence. I haven’t been able to find it but I believe someone did a comparison a few years ago between stock, a K&N, a mod like mine, a claw and possibly even the now discontinued ram air system that fed though a hole in the license plate cutout in the bumper.
As Paul has already said, the big gains are in the plenum/injector housing/head porting and headers.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 08-17-2018   #14
Ccmano
Ccmano's Avatar
Found it... over on Corvette forum. Dyno results included.
https://www.corvetteforum.com/forums...o-results.html
H
Old 08-18-2018   #15
Norwegianmopar
Norwegianmopar's Avatar
You are reading my question spot on.
Vararam emailed me yesterday and said this about my question about them having any systems for C4 Corvettes:
"Sorry - no - we have looked at them but can't find an effective way to make one."
Knowing there is a bunch of skilled and experienced members in this group I decided to make this thread.
Vis sitert tekst
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 08-18-2018   #16
Norwegianmopar
H
It's not the air filter system that we think is the restrictive part, rather the way the air has to travel to get to the filter box. The duct leading to the filter box is not in a straight line, but kinda S-shaped or zig zagging if you like.
This makes ram air effect hard to get; more cold air in as the speed increases. We believe there has to be a way to achieve this.
Imagine being able to get more cold air in and thus being able to get more fuel burned. Add this to the porting and headers etc in the other end of the power plant. In theory, that should bode for even more power gains than with today's amount of air getting in thru the existing intake system. Agree..?
We all know twin turbos or superchargers can help with this, but not for the same $$$ [emoji16]
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-18-2018   #17
Norwegianmopar
H
Yes I have read this thread too [emoji106][emoji4]
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-18-2018   #18
Norwegianmopar
This is the type of system I would love to have on my Z:
http://www.vararam.com/b2.html
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-18-2018   #19
efnfast
I would think some way to measure vacuum at the horn would tell you if there was enough restriction to matter.
Old 08-18-2018   #20
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
40 Horsepower add?
Marty
