Old 08-14-2018   #11
Default Re: Rebuilding front brake calipers?
GS calipers bolt in using same brackets and pads as the 91 calipers.. main difference is the face of the Caliper with 'CORVETTE' on it and the structure of the caliper was improved.
Warp Ten was referring to $50 for the regular replacements.. GS calipers will be a bit more money
Old 08-14-2018   #12
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
While you CAN rebuild them, I agree with the others, why?
I can likely make a cinder block, but if I only need two or three, much easier to buy them.
Cannot sing the praises of Lonestar enough!
Bair's also!
Jeff and Warp Ten are spot on in recommending the Grand Sport calipers, unless you are going NCRS, although I would still use the GS calipers and take the points deduction.
For looks alone, but they are better also which Jeff nicely pointed out.
A VERY GOOD upgrade!
Enjoy your project!!!!!!!!!!!!!!!
Marty
Old 08-15-2018   #13
Hib Halverson
It's only the 96 GS front caliper which is stronger. The 96 GS rear caliper is the same except for the black powder coating.
Front calipers are pretty easy to rebuild provided you have rebuild kits and the FSM. Actually, given regular brake system flushes, you'll find the calipers will have little wear except, if you drive hard, the front outer caliper dust seals may be burned or melted.
Rear calipers are a little more difficult because of the caliper-lock parking brake. Again, the FSM is your friend.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
