08-03-2018 | #11 |
Re: New exhaust - what to buy?
Hi Roy,
The dual mass flywheel will rattle if the engine is running rough. Does the car accelerate smoothly at low engine speeds below 3000 rpm? It should accelerate slowly but smoothly if you open the throttle 100% at 3000 rpm in fourth gear. Let me know what happens when you perform that test. Marc Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
08-03-2018 | #12 |
Maybe it's not the cats after all...maybe the exhaust leak and the engine running rough that produces that rattling sound. Dropping by a garage over here to have them check it out. Still have over 500 miles home from our roadtrip.
08-03-2018 | #13 |
I would certainly second the idea of Stainless Works headers, high flow cats and a Corsa cat back. But I also really liked my last approach on my '95 to utilize the stock '95 cat back system (behind SW headers and no cats) with electric cutouts just ahead of the rear mufflers. the center resonator on late model systems is pretty free flowing, and the cutouts give you the best of both worlds--quiet when you want it and wide open at other times. Marc Haibeck didi the excellent work on this and I fashioned my own under the carpet rocker switch. There are posts elsewhere on this.--Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 08-03-2018 at 11:17 AM. |
08-09-2018 | #14 |
You didn't say if Cats were required by law where you live. If not, the most free flowing system is headers, 3"X pipe, no resonator, 3" exhaust pipes and 3" mufflers of your choice. The sound of this system is a low rumble at idle, and very loud at high rpm. With lots of resonance, (many people find this offensive).
Corsa is very good at eliminating resonance, but has a high pitched shriek at full throttle high rpm. Some like this, some don't. How you want it to sound is really a subjective matter of taste.
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
08-10-2018 | #15 |
I must have cats over here. Any experience with X-pipe instead of the mid muffler..?
Would you recommend Dynamat or similar if headers are installed? Found out my cats are intact, it was probably the DM flywheel making the noice due to the car running a bit rough at the time. Sent from my SM-G955F using ZR-1 Net Registry mobile app
08-10-2018 | #16 |
Wouldn't recommend anything that would cause drone, at least not if you're going to use the car for such journeys you've just been on. My car came with mid muffler removed, and replaced with a rather poor x-pipe. Horrible drone at all cruising speeds.
I've got the Corsa now, no drone, and the volume is just within what I can withstand for longer periods.
- '90 ZR-1 |
08-10-2018 | #17 |
For headers go with the OBX. Best value out there.
08-17-2018 | #18 |
Have decided to get a x-pipe and will keep the Borla mufflers back rear and the stock manifolds for now. What and where to buy?
08-21-2018 | #19 |
won't work my friend. the cats are welded up on those manifolds
drop the exh and take a scope and a light and you can see if the cats have given up If there is a hole in any of the cells and they are falling apart un bolt them. They can't reasonably be fixed. Car needs headers anyway.
08-21-2018 | #20 | |
