Old 07-15-2018   #11
Hib Halverson
Default Re: DIS Unit.. is made of Gold?
While it is true that the DIS module sheds heat to the plenum, coolant running through the throttle body has no affect on the temperature of the rear of the plenum where the DIS module is located.
If I was worried about the DIS module condition, I'd get the plenum off, remove the module and clean it off top and bottom. Then I'd make sure all the pins of its 14-pin connector and its two 3-pin connectors are clean.
Then, I'd clean the mounting surface on the plenum. Once that and the module mounting surfaces are clean then I'd apply the dielectric grease per the Factory Service Module. Finally, I'd reinstall the module.
Before setting the plenum back in place, I'd look at the connectors at the ends of the DIS harness and make sure all their pins are clean.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-15-2018   #12
Originally Posted by Ccmano View Post
Holy crap...! Just caught this on EBay. Jerry I hope your project is going well. At this price we are pricing the Z out of existence!
H
https://rover.ebay.com/rover/0/0/0?m...2F223059459630
Actually gold pressed Latinum with unobtainium components
Old 07-16-2018   #13
Default DIS Unit.. is made of Gold?
I concur as I figured that TB coolant flow was a relatively small heat source just enough to keep the TB from icing in cold weather.... Thanks for the DIS reconditioning update
Old 07-16-2018   #14
HAWAIIZR-1's Avatar
I have to remember you are in Japan (time zone difference)
That was one of my temporary posts
The post was about Parts Hoarding
Or........Parts Investing
Can I use that? “Temporary Posts” I love it.
Ha, ha....yes you are a parts hoarder. You need PHA (Parts Hoarders Anonymous) treatment; there might even be a group here for that...lol.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-16-2018   #15
spork2367
H
That's not even the most expensive one to cross ebay.
Old 07-16-2018   #16
HAWAIIZR-1's Avatar
That’s it, I’m taking mine to the next Barrett-Jackson to auction!!!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-16-2018   #17
spork2367
Nice, I should be able to pick it up there for about 1500....lol.
Old 07-16-2018   #18
HAWAIIZR-1's Avatar
Reserve set at $2K....,lol.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-16-2018   #19
spork2367
Haha.
Old 07-29-2018   #20
Scarabexc
Been trying to reach you,,, do you want this one back?
Scarabexc is offline   Reply With Quote
