Old 07-05-2018   #11
Norwegianmopar
Norwegianmopar's Avatar
Default Re: Motor wash tips
This is what the good mr Haibeck told me:
"We use liquid dish soap from the kitchen in a spray tank. We spray everything except the top of the engine with soap and rinse it with a soft spray of water like as if it was raining on the engine. The electrical seals are designed to keep rain out but not water under pressure. Never let water spray on top of the plenum. If more than two ounces of water goes between the runners it can damage the starter. Never rub on a hot engine. The heat softens the finish leading to scratches. Clean the top of the engine with a wet towel. After the cleaning is done, drive the car at least 20 minutes so that the heat will dry things out.
Best regards.
Marc"
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 07-06-2018   #12
rkreigh
you don't need much, I haven't tried alchohol and that works for most of my issues so that will be next
I typically just used clean damp towels and those little spongy sticks (thanks mom) for the tight areas
I just pulled my top end apart and was surprise how really dirty it is.,
95 390 LPE ZR1 (505 rwhp)
