#11 | |
![]() Join Date: Jun 2005
I should have maybe added something like "...more than a little...". I agree that a little oil smoke on cold starts is indicative of a 90 w/o exhaust valve stem seals and with some miles on the engine. I've often wondered why Lotus and GM did that. I've also often wondered if the reason that happened.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 07-01-2018 at 11:09 AM. |
#12 | |
![]() Join Date: Nov 2007
So, the description of the lack of oil seals might should be refined to specify: "At startup" BLUE (oil) smoke appears after the motor was at rest and is more noticeable the longer the motor was at rests up to (say) overnight. However, if smoke of any color persists, and especially under heavy throttle, then more serious issues exist beyond mere valve stem oil seals". As for why they didn't install the seals on the exhaust stems in the first place, I believe I read it somewhere - sort of tongue-in-cheek, "Oil consumption?? Hey, it's a British thing!" ![]() |
#13 |
I still keep touch with some of the guys I met from Lotus and MerCruiser back in the "old days", and I emailed one of them yesterday.
He told me during development they figured exhaust pressure would keep the oil off the stems when the engine with running but they did not figure on engines with some miles on them starting to leak down the exhaust stems when the engine is stopped. That's why for 91, they added stem seals. He made the point that when the engines were new or near-new, even without exhaust valve stem seals, they wouldn't puff oil smoke after cold starts. When he said that "engines with some miles on them" didn't necessarily mean "worn" but that worn engines would have a worse problem with that.
