Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 06-19-2018   #11
Karl
Karl's Avatar
Default Re: Beast #2 heads to Chicago!
That was Beast #1.
I have not been to the NCM in quite a few years....
Old 06-20-2018   #12
Karl
Karl's Avatar
The car has arrived.
Old 06-20-2018   #13
conesare2seconds
Great. Glad it went to a good home.
Old 06-24-2018   #14
Karl
Karl's Avatar
Took some pictures today.
Old 06-24-2018   #15
Karl
Karl's Avatar
I need to register the car.
I managed to take a quick joy ride around the neighborhood and the car with the 4.09 gears is pretty fast. Easily spins the tires through first gear.
There are a few miscellaneous problems.
1) ses light with a code 16
2) waiting for delivery of the driver side headlight cover.
3 the center digital display does not work. No mph, fuel level, etc. Gotta fix that.
Besides that the car is very clean and with the old b&b exhaust loud too.
Old 06-24-2018   #16
Karl
Karl's Avatar
I am planning the following mods to the car:
1) lightweight flywheel
2) Camaro clutch
3) lightweight pulley set w/underdrive for the water pump.
4) x pipe to replace resonator
5) coil over suspension
6) Vette 2 Vette frame stiffeners
7) oil catch can
8) relocate battery to rear
9) silicone hoses
10) short throw shifter
11) zd doc beam plates
12) drm camber rod brackets
13) ACI cold air intake
14) Dewitt's aluminum radiator
Old 06-24-2018   #17
It has 2 roofs right? is the acrylic roof cracked? looked like it in one of the earlier pictures.
Are you sure it does not have the aluminum flywheel?
Which Short Shifter?
Old 06-24-2018   #18
Karl
Karl's Avatar
I need to double check the ses code too. I forget if it was 61 or 16.
I have both tops and the clear is not cracked. I will double check it. I have not had much time to work or look at the car until this weekend.
Going with either a Hurst of zf doc shifter.
I hear no rattle and no mention in the records of a light flywheel installed.
Old 06-24-2018   #19
could have been power lines across when looking up and through in one of the pictures I saw which is why I asked
Old 06-24-2018   #20
Karl
Karl's Avatar
No problem. The car will not be winning any NCRS awards for being all original!
But I really like it and everyone who didn't buy this car missed out on one heck of a deal and car.
