Old 06-18-2018   #11
Default Re: R-12 to R-134 conversion
I don't think Marc will have a problem with me posting his response to my inquiry re:134a. Looks a bit less involved than we may have believed. I will swap out the high side switch, just in case, but otherwise...
Hi Dominic,
The OE o-rings and switches are compatible with R-134a refrigerant. I have a GM service bulletin advising that. Only three things are needed. 8 oz. of PAG oil, service port adapters for R-134a and the refrigerant.
When installing a new compressor, it's a good idea to install a new filter/dryer and a new filter/orifice.
Best regards.
Marc
Old 06-18-2018   #12
jss06c6
Excellent information.. wouldn't expect anything less from Mr. Haibeck!
Old 07-03-2020   #13
S.hafsmo
S.hafsmo's Avatar
Hi Dominic,
Best regards.
Marc
This is correct? You do not need to replace expansion valve, compressor, condenser, pressure switch etc.?
Is there any way to tell if the system is already converted?
Drier and orifice recommended, I see.
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 07-03-2020   #14
Yes. Marc once showed me the GM service bulletin on the subject back in the late '90s when I had my '93 converted. And I think that the fill valves are different for the R-134a than the R-12 but not certain; others know better. --Bob
Old 07-03-2020   #15
If I recall fill for R134a is maybe 90% of R12
Old 07-03-2020   #16
mhobtr
The low pressure switch is the same but there is a small screw between the wire terminals that is turned to adjust the low pressure cutoff.
IIRC the low pressure cutoff is 24psi for R-134a and 22psi for R-12 but you need to check the service manual to be sure.
mhobtr is offline   Reply With Quote
Old 07-03-2020   #17
Ccmano
I can tell you that back in the day when I was doing these we only replaced the orifice valve (R134 specific), installed an R134 adapter, evacuated the system, added PAG oil and recharged with R134. A they always worked just fine. I believe any orifice valve you get today will be R134 compatible.
H
Old 07-03-2020   #18
viper107
viper107's Avatar
i have just allways screwed on the 134a fittings to the hoses and shot the system, blows ice cold if the system is healthy, never changed nothing
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5
viper107 is offline   Reply With Quote
Old 07-05-2020   #19
jss06c6
Old thread..
I replaced my condenser (source of leak), compressor (R134 version), dryer and orifice tube. No pressure switches were changed.
I changed the compressor to a NOS unit "while I was in there". Dryer swap good practice. Put in 8 OZ PAG 100. Vacuum for 2 hours. Tight as a drum 24 hours later.
System took 1.83 lbs R134A. Blows cold with no issues.
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 07-20-2020   #20
Ccmano
Looks like I need to replace my condenser. I plan to replace it and the dryer/accumulator. The compressor was replaced a few years ago. Can't tell if the system is running on R12 or R134a. I plan to recharge it with R134a. Does 4.5oz of PAG 100 oil (per the manual) sound correct since I'm not doing the compressor?
H
