Old 06-11-2018   #11
Default Re: 1990-1995 ZR-1 AC Condensers
7-4306
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-11-2018   #12
7-4306
got it.. is the PN stamped on it anywhere?
Old 06-11-2018   #13
Its on a tag attached to the bracket that holds the hose ends in place. The box also says 4306.
Old 06-11-2018   #14
this does not help you, but this is the part I bought
P32603P I got it at autoparts warehouse and no longer shows on their website
a link to one
http://autopartsvalley.com/autoparts...2603p-52456459
Old 06-11-2018   #15
All the online catalogs show the OHV and DOHC condensers as the same part# which end w ..306. The pics used appear to show the correct part, but the one I got from AZ doesn't look like that. Taking it back for refund.
Old 06-11-2018   #16
Can you get me a picture of the other end of both of them?
Is ti the same width? I see the core height is less but the frame 'end' structure looks the same height. How far off are the fittings? inches? 10ths of inches? 100ths of inches?
I seem to remember mine being a pain and did not quite line up..
Old 06-11-2018   #17
WVZR-1
a link to one
Industry interchange says your ref# and the one he was sold are same applications. It can't be an '89 as the '89 stood straight up and the fitting were 'parallel' with the floor.
Old 06-12-2018   #18
yeah, thanks.. I seem to recall having to 'adjust mine a bit' to work. 8 years no leaks
Old 06-12-2018   #19
Got a refund from AZ. Very straightforward. Picking up a used condenser from Vette2Vette today. Jason said he has several 90-93 units in good condition that hold pressure. New compressor and tensioner are in.
Old 06-12-2018   #20
I should add that the Parallel Flow condenser while it may need a bit of tweaking, being parallel flow is suited more for a R134a system.
As some know on a typical R12 to R134a conversion the R134a tends to run a bit higher head pressure than R12. the Parallel flow will help alleviate that. in fact my R12 system with the parallel flow compressor I barely notice the added load on the motor due to the nature of the parallel flow vs the OEM Tube and Fin
While I understand some want the OEM fit and drop in, this will help others when looking to fix there systems
Happy Cooling
