05-17-2018 | #11 |
Re: Alternator
Buy Jerry's.... You'll waste time/money everywhere else. If you send your original in, keep the original pulley. Jerry's comes with a smaller pulley, if you spend a lot of time near the rev-limiter it could lead to Alternator SIDS.
I pull the upper plenum and the alt can be done in 45-mins. Good time to wire the secondaries open as well
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
05-17-2018 | #12 |
Re: Alternator
Easier just to pull the air horn.
Lou
05-18-2018 | #13 |
Re: Alternator
I'm with you on this one. I've got a step-by-step with needed tools here: http://www.zr1.net/forum/showthread.php?p=248848 Sent from my iPad using ZR-1 Net Registry
1991 ZR-1 #1438 Black/Black & Red |
05-18-2018 | #14 |
Re: Alternator
I have twice now replaced alternator. I removed throttle body. Did not have to remove oil sender or tensioner. First time I had unit "rebuilt" last November. Replaced it with one of Jerry's on MR6 two days ago. Thank you Jim Voter! However I believe the easiest would be to lift plenum. As long as you have gaskets.
05-18-2018 | #15 | |
Re: Alternator
Ah, yes. Throttle body remove would make it so you wouldn't have to remove the oil sender. Probably makes it easier to access behind the alternator for (+) terminal too. Many ways to skin this one
05-18-2018 | #16 |
Re: Alternator
We did it in 2 hours in parking lot with just the minimum of correct tools.
