Old 04-27-2018   #11
jss06c6
Default Re: Short idle/engine Issue
Do you have a way to log engine data? Would be great to see how your O2 sensors are behaving as well as the BLM data when the engine transitions to closed loop.
Hans, what system are you using?
Old 04-27-2018   #12
Ccmano
Steve,
I use ALDLDroid on an Amazon Fire 7 tablet, with a Red Devil River Bluetooth adapter.
Works great. Any android tablet will work.
H
Old 04-27-2018   #13
Originally Posted by TealZR1 View Post
thanks JSS and Gold - yes fairly recent since I had an antifreeze leak at the TB. I had Haibeck service the TB and reinstalled but I am wondering if the antifreeze possibly started another issue like contaminating one or both 02 sensors.
If I get it on a scanner next week what should I look for?
Anti-freeze will "F" up an O2 sensor along w silicone sealer. Swap them out just to be on safe side.
Old 04-27-2018   #14
If you have a scanner you can see the BLM counts from each 02 sensor increasing and decreasing the counts from side to side. However Dom is right on what a bath of antifreeze could do to a sensor
Old 04-28-2018   #15
TealZR1
That ALDLDroid adapter kit is a must - and I happen to have an Amazon 7 Fire Tablet!!
Done deal for under a hundred bucks! Thanks for suggesting Ccmano.
TealZR1 is offline   Reply With Quote
Old 04-28-2018   #16
Ccmano
FYI... you will need the load the Google Play Store to download the app. Amazon is a derivative operating system to android. In other words it’s Android but to Amazon spec. Directions are on the on the net. Here is one. Once this is done the app can be loaded and operated.
H
http://blog.the-ebook-reader.com/201...-in-5-minutes/
