Old 04-20-2018   #11
Default Re: 2019 ZR1 @ Drag Strip WTH!!!
Originally Posted by efnfast View Post
Somebody tell me where a kid like this gets the money to go out and beat on a brand new $130,000 car.
As stated YouTube "star" a lot of others have done it as well
Old 04-20-2018   #12
Vette73
I said the same exact thing..He also owns a home and a brand new McLaren....Did a little research on him....He actually has over 700,000 subscribers for his you tube handle street speed 717.....
From what I hear he makes 12,000 a month from you tube alone....I would guess that figure is a little high.Its probably close to ten grand a month ..
He works for a small brokerage firm and I would guess his salary is maybe about 40-50 K from that..He also invests on his own....
He actually is well spoken and really has made a name for himself with his you tube videos....
Vette73 is offline   Reply With Quote
Old 04-20-2018   #13
G-Sting
G-Sting's Avatar
Originally Posted by Hog View Post
That first run he was out of the throttle before he was through the mph trap. Appears to have shut down before the finish line.
All else equal, the mph would increase with some more miles. These arent the lightest Vettes either. That orange #4 ZR1 did dyno at 688rwhp.
A 2016 ZO6 has run a 10.0@132.7mph (Road & Track)with ONLY 650hp/650lb/ft torque.
I am seeing reports of 10.12@ 135 for stock 2019 ZR1's.
Today's CF article shows this as well. 2019 ZR1 stock with drag radials. https://www.corvetteforum.com/articl...-quarter-mile/
cheers,
G
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Old 04-21-2018   #14
Hog
cheers,
G
Very nice, look at that 60ft.
Old 04-21-2018   #15
Hog
The 8 speed auto allows for drama free launches. 1.58 60ft, stock torque converter, and the stock (auto) 2.41 rear gear and it's 1st gear ratio of 4.56:1 ,
2nd 2.97
3rd 2.08
4th 1.69
5th 1.27
6th 1.00
7th 0.85
8th 0.65
As we saw, the auto equipped '19 ZR1 was decently into 5th gear as it trapped.
The manual 7 (TR6070) speed gets the 3.42:1 rear gear and if the Z06 and ZR1 share the same TR-6070 trans ratios, it will have a 2.97:1 1st gear
2nd 1.61,
3rd 1.21
4th 1.00
5th 0.82
6th 0.68
7th 0.45
Old 04-21-2018   #16
lfalzarano
You are correct, both Z’s use the same manual, but the ZR-1 has s torque reduction to protect the 1st 3 gears. The auto is likely faster.
Old 04-21-2018   #17
Vette73
What's exactly torque reduction? Crazy.....Soon there will be no more manuals....
Old 04-21-2018   #18
BigJohn
BigJohn's Avatar
It is so you don’t have a drivetrain failure.
Old 04-22-2018   #19
Hog
There aren't many GM vehicles built since 1992-93 with the advent of the 4l60e transmission that don't have some sort or torque reduction or torque management. It was usually reserved for automatic transmission equipped vehicles. Many would drop engine timing advance during upshifts.
I wonder how the application of torque through a clutch as in the manual differs compared to the application of torque through a torque converter as in the auto trans vehicles?
Are the manual cars more apt to have the front end swap positions with the rearend?
Torque reductions is mentioned as part of the many nanny controls of the new Z.
Active handling stability control with traction control
  • Automatically helps enhance control, particularly during emergency maneuvers, by adjusting the brakes and engine torque to keep you on your intended path
  • Activates when vehicle sensors detect a difference between the driver's intended path and the direction the vehicle is actually travelling
  • Includes Traction Control that detects wheel slippage and applies brake pressure and/or reduces engine power to help the driver maintain control when accelerating on wet or snow-covered roads
Traction control, all-speed Performance Traction Management
  • Available in the Track mode of the cockpit-mounted Driver Mode Selector
  • Offers 5 settings of torque reduction and brake intervention for enhanced track driving performance
  • May require additional optional equipment
Old 04-22-2018   #20
lfalzarano
There is a “ kind of predictive algorithm found in the dual clutch (automatics) to prepare for the next likely shift,” Alex MacDonald, Chevrolet’s Vehicle Performance ma manager.
