#11 |
I would happily run my stock ZR1 against the 1966 in question for titles if the new owner would be willing...
#12 | |
![]() Join Date: Jan 2015
Sweet Sent from my iPhone using ZR-1 Net Registry
1990 ZR1, 1987 Mustang GT (since new), 1973 DeTomaso Pantera, 1987 928S4 Passed on: 1984 930S (gray market), 1988 Mustang Coupe Trooper car(drag) |
#13 |
![]() Join Date: Feb 2014
#14 |
![]() Join Date: Jul 2005
In April of 1966 I drove a new 66’ convertible 427/450hp. Flat out to 155mph, at that point aero was taking effect, with front end lifting and tires bobbing on the ground. I backed off. There is no way the car would have come within 10-15 mph of my ZR-1. The C4 ZR-1 is the fastest factory stock GM production car of the 20th Century.
#15 | ||
![]() Join Date: Jun 2013
Taken from a post in the other forum: Here are some ETs that car magazines reported from their road tests: 1. Motor Trend tested a 1964 model 327 / 375 hp fuel injected with 4.11 gears and turned a 14.2 @100 2. Road & Track, 1964 model 327 / 300 hp automatic did a 15.2 e.t. 3. Car and Driver, 1965 model 327 / 350 hp and 3.36 gears got 14.9 4. Road & Track tested a 1965 model 396 / 425 hp with 3.70 gears and complained about wheel spin and turned a 14.1 5. Motor Trend, 1967 model 427 / 435 hp with 3.55 gears did 13.8 @ 104 mph. 6. Car and Driver 1967 model 427 / 435 hp got 13.6 @ 105. EDIT: 7. C&D, R&T and MT did 4 tests on 1966 and 1967 427 / 425 hp and the average of those were 13.53 @ 107.6 mph. 8. Car and Driver 1968 model 427 / 400 hp did 14.1 @ 102 9. Car and Driver 1971 model (GM mandated lowered compression beginning with this year) 350 LT1 making 330 hp with a 4 speed and 3.70 gears hustled down the strip at a 14.57 @ 100.55 10. Car and Driver 1971 model LS6 solid lifter 454 / 425 hp with double-disc clutch & 4-speed turned a 13.8 at 104.65 with 3.36 gears. EDIT: #11. See post later in this thread re the L88. *11. Car Life, model 1969 L88 427 / 430 hp, 3.36 gears, automatic, 14.101 @ 106.89 and top speed of 151 mph. * Car Life couldn't quite match that number for its June 1969 issue. Their test L88 could only muster a 14.101 at 106.89 mph; and judging by the mph, it looks like the L88 imposed its will on those poor little F70 tires. If set up right (gears, sticky tires, headers and sidepipes), the L88 would annihilate anything in its path. Even though handicapped with 3.36 gears and an automatic (1 of 17 built with an automatic), the L88 did shine for Car Life by posting a top speed of 151 mph. The editors pointed out that the car could have gone faster if pushed to the very edge, but they chose to keep it safe." Also this, but unverified and a bit hard to believe, even with slicks: One other item of note - A factory 1969 ZL1 (which is an L88 with aluminum block and heads) with 4.88 gears turned a 10.9@132mph with slicks when GM tested it. Obviously not stock gearing or tires. |
#16 |
I believe those last numbers because the trap speed indicates 525-550hp., Which is what an L88 actually has, (according to best estimates.)
But these are all qtr. mile numbers. But I thought we were talking about speed = top end? The Car Life editors proved my initial post, which stated that C2 Sting rays are limited to less than 160, due to aero, no matter what the horsepower. Sent from my iPhone using ZR-1 Net Registry |
#17 | |
It wouldn't even be in the top ten list. Every C6 (LS2, LS3, LS7, LS9) and C5 (LS1, LS6) model would beat it, as would the LT5, LT4 and LT1 C4s. So if you looked at just engines it might be number 10 (if it beat the L98), but if you look at models, it definitely wouldn't. Last edited by spork2367; 04-16-2018 at 03:53 PM. |
#18 |
I would love to own a Pantera. I drove one years ago and it was one of the insane cars to drive and the prices of these are through the roof. The ZR1 is the better deal as of now. I couldn't afford to fill my 1983 honda accord with gas when the ZR1 came out and now I own one. Can't be any more happy.
