04-09-2018 | #11 |
Re: Flying 1/4 mile racing
That was absolutely AWESOME, Glen!
Thank you for the videos. Your car sounded great and was very stable. This is an event perfect for our cars: Torque/HP and aerodynamic. I have done this on smooth (sometimes) and wide runways. This was NARROW! No doubt, you have kahunas! As said before, good, new tires are safety #1. And a trick for next time: Shift into 6th when you are done to slow down. Then brake and downshift. The Mojave Magnum (1.5 miles) is this coming weekend. I'm missing it for various reasons. Your videos make that even more sad. :-( Ted |
04-09-2018 | #12 |
3.45 gears?
04-09-2018 | #13 |
At least there weren't any trees or fence post you would hit if you went off road
04-10-2018 | #14 |
04-10-2018 | #15 | |
Sent from my SM-G930F using Tapatalk |
04-10-2018 | #16 | |
04-10-2018 | #17 | |
Regards Glen 20180407_111123.jpg Sent from my SM-G930F using Tapatalk |
04-10-2018 | #18 |
04-10-2018 | #19 | |
matching your engine and gears to achieve the result you want, in this case top speed. Even transmission gear ratios can be changed. Obviously, depends on how deep you want to get into this (& $$). That diffuser is AWESOME! In place of the spare? This is the ultimate, I believe: Dave (Daves Obsession), from Texas has a ZR-1 Bonneville car he talks about: https://www.corvetteforum.com/forums...t-up-date.html Lots you can learn from this. You can surely get hooked on this kind of racing. |
04-10-2018 | #20 |
