Old 04-09-2018   #11
Default Re: Z won't start...
Originally Posted by rush91 View Post
No they didn't bend, but even with extra lever, wouldn't budge.....
Sent from my XT1585 using Tapatalk
It takes a lot of pressure. On one I did I was thinking I would twist the Oil Filter Adapter off the block
I assume you did not damage the flats on the fittings?
Old 04-10-2018   #12
rush91
No I was careful...overly carefully I think. I didn't want to damage anything. The flats still grab the wrench fine.
rush91 is offline   Reply With Quote
Old 04-10-2018   #13
rush91
So turns out it WAS the battery....after testing the voltage, it was way low. Took it in to get a new replacement under the warranty. hook it up and this happened......my radio doesn't work, and the antenna has NEVER gone up in the 3 years of ownership. Quite puzzling.....
