Old 04-05-2018   #11
WVZR-1
Default Re: HELP - LT5 Idle Air control connector
This is a release tool that will reach a "Pull To Seat" terminal tab. The actual GM/Delphi tool was just a 'vise device' with a twist to tighten like a Dremel etc. You need to enter the rear of the shell.
Delphi vice is a 12180559-1 Understanding the length and the very small awl type point I'm sure the creative mind can sort it. Release shouldn't be an issue.
https://www.amazon.com/Rennsteig-Sup.../dp/B00A8GL7NA
If this link works it would be the GM/Delphi device.
https://www.ebay.co.uk/itm/GM-Delphi...75.c100623.m-1
Old 04-05-2018   #12
jrd1990zr1
jrd1990zr1's Avatar
I found a vendor for the connector and terminals.
https://www.bmotorsports.com/shop/index.php
They look to have all the connectors we would need.
Thanks to all for the help. John
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 04-05-2018   #13
tpepmeie
Yes. They are quite good, I use them often.
Todd
____________________________________
*** our email address has changed!
info@pepmeierengines.com
pepmeierengines.com
Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384
Pepmeier Engine Development
Old 04-11-2018   #14
jrd1990zr1
jrd1990zr1's Avatar
Got the replacement connector and terminals from Ballenger Motor Sports. Made the new connection, looks like OEM.
Thanks to all for the advice and help.
Old 04-11-2018   #15
Ccmano
Ccmano's Avatar
Did you get the pigtail and splice it in?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 04-12-2018   #16
jrd1990zr1
jrd1990zr1's Avatar
Hans,
I bought a new connector and terminals from Ballenger Motorsports and installed the connector, new crimps. Did not want to splice in pigtails. Wanted it to appear OEM.
H
Old 04-12-2018   #17
Ccmano
Ccmano's Avatar
Hans,
Nice... what are the part #s? I have to do mine too.
Thanks
H
Old 04-12-2018   #18
Hans,
John,
There’s enough wire to do that? I need to replace mine also.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-12-2018   #19
jrd1990zr1
jrd1990zr1's Avatar
Thanks
H
Ballenger Motorsports. Link in my previous message above.
CONN-75638 GM Delphi / Packard - 4 way metripack 150.2 sealed male connector Kit for iac, black
The terminals are PULL 2 SEAT, in other words you release them from the wire side with a double prong tool. Push them out the front.
Jim Voter's post shows a picture of the tool. I removed the short section of conduit to give some room for the repair. Pulled the rear rubber back to access the rear of the plug, then released the 4 wires one at a time. I opened up the rear crimp on each metal terminal and cut the old terminal off. I only lost about 1/8 inch of each wire. Moved the wires to the new connector and crimped new terminals on then seated them into the plastic connector. Just remember you crimp the terminals on AFTER the wire goes thru the connector. Put the conduit back on. Pretty simple job actually, sorry I waited so long to fix it.
Old 04-14-2018   #20
Just as an "FYI", another supplier I've used and had good experiences with (connectors and such) is Del City.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
