#11 |
![]() Join Date: Oct 2017
Looked around for the rear jacking adapter. Believe it was available from the "Corvette Gadget Man".
Appears he may not still be around. Do a search for him & you will find some pics of the adapter.
Kenny 1990 #442 ![]() |
#12 |
![]() Join Date: Nov 2007
I hear ya! I follow the pinch-weld forward of the "designated jacking point" (printed on the rockers) to where it curve toward the middle of the car and away from anything my floor jack is going to interfere with. Then I place a jack stand ahead of that - along that same pinch weld. NO SPECIAL ADAPTERS NEEDED (I find).
BTW, the article you referenced was mine. So, if you need clarification(s) or whatever, let me know! ![]() |
#13 |
![]() Join Date: Nov 2014
I kind of wondered the same thing..? Maybe someone can post a photo with an arrow , showing where the jack should safely go...👍
Sent from my LG-TP260 using ZR-1 Net Registry mobile app |
#14 | |
![]() Rear just in front of rear Wheel Well between two Hash Marks ![]() The Best Jack is this 3 Ton Floor Jack from Harbor Frieght ![]() See Lifting the ZR-1 for a specific discussion regarding lifting the ZR-1 with a floor jack, jackstands, and ramps.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-25-2018 at 01:06 PM. |
#15 | |
Thank you..... Sent from my LG-TP260 using ZR-1 Net Registry mobile app |
#16 | |
![]() Join Date: Feb 2011
That’s the jack I got. If your tire goes flat, this is the only one to get you out of that bind. Plus it is light and not expensive![emoji482] Sent from my iPhone using ZR-1 Net Registry |
#17 | |
![]() Join Date: Aug 2017
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Last edited by cruban; 03-25-2018 at 09:39 PM. |
#18 | |
![]() ![]() I think I will get a couple of those ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-25-2018 at 11:26 PM. |
#19 |
![]() Join Date: Jul 2016
Ordered a set and will try them out. Thanks for the recommendation.
#20 |
I use my jack on the pinch weld close to the rocker as possible but underneath the car and place the jack stands further forward along the pinch weld as they get closer to the motor. Ill see if I can dig up a photo to better explain it
