#11 |
![]() Join Date: Oct 2004
i was surprised to see the HEX on the header EGR - all I'd ever seen previously had the connection that required an OE clamp. Was/is the HEX actually 'free spinning' and threaded?
LT5 EGR '93+.jpg OBX LT5 EGR.jpg Last edited by WVZR-1; 03-25-2018 at 01:18 PM. |
#12 |
![]() Join Date: May 2012
They should sell 2 versions and save themselves time/money putting on at all, think about the numbers of cars 90-92 vs 93-95. They could probably not put it on at all for 80% of them.
#13 | |
#14 |
![]() Join Date: Jan 2015
#15 |
#16 | |
Yours is what I'd have expected I might have tried to ID the thread and use a mating male fitting of sorts. I would have thought choosing the option of threading the ID of the tube a better choice could have been made. Your choice works for you so it 'matters NOT'! Last edited by WVZR-1; 03-26-2018 at 07:31 AM. |
#17 |
![]() ![]() Join Date: Aug 2005
I learned this from Marc Haibeck:
It uses a compression clamp (and special tool) called a Oetiker clamp. #7 in above drawing. Look it up! Found it! Jerry's Gaskets (of course!) http://www.jerrysgaskets.com/clamp-e...new-90-95-2c4/ zr1assassin: If you use the EGR system, its a compression connection egr to nipple on exhaust. No threads, stock no nut. Last edited by tf95ZR1; 03-29-2018 at 01:00 AM. Reason: Wanted 2 |
