Old 03-16-2018   #11
Wigert
Default Re: Coolant leak
Originally Posted by RussMcB View Post
(forgive me if I've posted this before - I probably have...) I bought mine 20 years ago for < $100 and it has been a great investment. I use it often, and often lend it out. Sometimes you need to buy an adapter if your radiator cap isn't "regular ole American" (like my Miata). On my race car, whenever I've done stuff with the cooling system, I check if it holds pressure, It always tells me if something's not tight. It's great to find problems in the garage rather than away from home.
Thats also a good idea, I will have to google it and see if I can find a good source.
Skickat från min GEM-701L via Tapatalk
Wigert is offline   Reply With Quote
Old 05-16-2018   #12
Wigert
I just wanted to close up on this thread. After replacing the thermostat and some of the cooling lines with parts from Jerry's the coolant leaking has ended. I want to thank you all here for the support. The putty knife tip was very useful I might add.
