Old 02-24-2018   #11
Default Re: Electronic Spark Module ... future MY 90 Achilles Heel?
Doubtful Hans given that the L83 and L98 were iron blocks and ours of course is aluminum/open deck. Not to mention the valvetrain noise. Frequency filtering would be different.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-24-2018   #12
I am sure they are different in some way.
Old 02-24-2018   #13
Yep the form factor is identical however there is an internal reason why the Part numbers are different as the 90 ZR-1 has its own part number. GC
Old 02-24-2018   #14
While almost everybody knows about the ECM and the DIS that are failure points along the entire model run I propose that I have stumbled upon a MY 90 potential problem area that I was completely unaware of. While I am fairly knowledgeable about ZR-1s I will be the first to tell you I know several members in the community that have probably forgotten more than I will ever know lol.
The ESC is also called the electronic knock module. It provides an modular interface between the knock sensor and the ECM.
Just my thoughts your mileage may vary. GC
I might add one other item that can fail
I would say Fuel Pressure Regulator (FPR)......and yes.....your milesge will vary when you start sucking raw fuel into plenum when the FPR fails
Old 02-24-2018   #15
Mechanical issues have had “work arounds” and adaptations but when it comes to electronics we are in a totally different realm.
Let me just add that this is the type of initiative the Registry needs to be more pro-active in to fulfill our mission statement of “Keeping the Legend Alive”.
Old 02-24-2018   #16
Concur. I know Jerry is working on a solution for the DIS on his own dime and we would be in a real hurt lock real quick if folks like Phil had not put together a solution for the fuel pressure regulator. I had a good discussion with Dom last night with electronics we are all on borrowed time. Even having a replacement used part on hand is not a long term solution. It is concerning. GC
Old 02-24-2018   #17
It also looks like somebody took my advise and bought that module on EBay.
I hope it went to a club member as I did not put this info out on Corvette Forum. GC
Old 02-24-2018   #18
Scrrem
Scrrem's Avatar
Yes it did and thanks! I have been meaning to pick one up for a while and you reminded me. I have never heard of one of these going bad but you nene know.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-24-2018   #19
Ccmano
Ccmano's Avatar
Doing a little research over on Corvette Forum in the C4-Tech-Performance (not ZR-1) section. It appears that 16080211 is the Knock module for all 90’s not just the Z.
Does anyone have a parts cross reference to confirm this?
Check out the last post in this ancient thread.
https://www.corvetteforum.com/forums...dule-part.html
This exact reference comes up in a number of threads with regard to “false knock “ in L98’s.
“The part numbers for different years are:
'85-'86 p/n 16022621 - New p/n 16126761
'87-'89 p/n 16052401 - New p/n 16038331
'90 p/n 16080211”
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 02-24-2018   #20
Default Electronic Spark Module ... future MY 90 Achilles Heel?
I will check a 1990 (L98) tomorrow for knock module. Pete should also have one on that 1990 Z he is parting
out.
