02-21-2018 | #11 |
Re: Oil Smoke - Input
Dom, all I have to do with mine is let it sit and warm up. Once hot and you rev the engine it will put a good amount of blue smoke out the right side exhaust.
Prior to this oil consumption was negligible. So something changed. H
02-21-2018 | #12 | |
My post was not intended to address your particular situation. It really was directed more to gt. You and I have discussed the similar symptoms my motor was exhibiting last year just prior to and during the MR5. And ultimately what Dr. Greekenstein diagnosed.
02-21-2018 | #13 |
Just following along here...
Assuming (for now) the "given(s)" are correct, the only thing exclusive to the one bank are the pistons/rings and the head (including valve/guides) IIRC, when I did the compression check on Dom's car, compression average differed bank to bank, BUT there wasn't really anything that jumped out, far as static compression test goes. And again, IIRC, Dom's oil consumption was similar to what you are describing. I don't remember if Pete did a leak-down test, but I do recall Dom had a cylinder that did have fouling in excess of the others. (Dom remembers if that plug was in the cylinder with the broken ring.) So, I don't think a leak-down test is out of line: hate to assume b/c static compression was good that a ring is eliminated. Has happened B4! In the end, the motor was pulled and broken down and the broken ring was discovered upon disassembly. I know I was a little surprised at the broken ring. There wasn't any of the catastrophic "stuff" that usually goes along with a broken ring, far as I know. Then too, it could be something off the wall - like...IDK...a valve seal breaking or the (off-the-wall) like? I'd want to eliminate everything I could to avoid pulling the motor - that being the last resort, but the best way to explore every nook and cranny. (Would be a good time to refresh the bearings and rings, etc., anyway, huh?) Going back to my now...
02-21-2018 | #14 |
Paul,
I have found only two instances of this documented previously. One was Doms with the broken ring. The other was back in 2014 on a 368. That turned out to be a collapsed oil ring. If I’m not mistaken Pete diagnosed and repaired both. So it’s trending in that direction. I’m keeping my fingers crossed it’s stuck oil ring that can be loosened. I may run a leak down in a few days when the temps here climb over 40 again and my back, which I put out this morning, gets better. Btw, no valve seals, it’s a 90’. H
02-21-2018 | #15 |
For those following this thread. Lee (Lgaff) and I have been talking off line. He has 2 sets of low mileage stock liners. All show the same vertical scuffing mine seem to show. Appears unlikely that this is related to the current condition discussed here.
H
02-22-2018 | #16 |
Do you still have the original exhaust manifolds/cats installed?
02-22-2018 | #17 |
No it has headers and exhaust. This started after I installed them. One of the reasons I did that was because of my concern at the cats breaking up.
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. Last edited by Ccmano; 02-22-2018 at 10:22 AM. |
02-22-2018 | #18 | |
Interesting. Could oil somehow be getting introduced into either the combustion chamber or into the exhaust stream somehow? Seems awfully coincidental and odd that the problem appears simultaneously to the installation of the headers. There is an answer there somewhere. Hmmm........................... Marty |
02-22-2018 | #19 |
Re: Oil Smoke - Input Needed
The only remotely possible area of oil introduction that I am aware of is at the header stud. No way to get into the combustion chamber from there. Generally just causes a leak or oil burning off the header. I my situation oil is getting into the combustion chamber and causing smoke out the exhaust.
H Sent from my iPhone using ZR-1 Net Registry
02-22-2018 | #20 |
Maybe the correlation is that after 28 years, something is going to give when u push it a bit. My motor had about 70k on it when this happened. And I recall seeing puffs of blackish-gray smoke upon harder acceleration right at the beginning of the season last year. I thought it was just the motor blowing out some carbon.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 03-08-2024 at 03:10 PM. |
