Old 02-04-2018   #11
lfalzarano
Default Re: Need Help Diagnosing This Sound
You are very lucky man. I screwed up once on my Triumph TR4 in college. It took out part of the rear fender, 3 inch drop to the roadway was frightening at speed and of course the 180 degree spin was a nice touch to my date... Thankfully, we had quite a few that evening (legal back then), so we laughed it off.
Old 02-04-2018   #12
Yeah, could have been a disaster
Old 02-04-2018   #13
Ccmano
Ccmano's Avatar
It’s always the simple things that come back to bite us. Glad you found it.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 02-04-2018   #14
billschroeder5842
billschroeder5842's Avatar
Originally Posted by jcruz View Post
I'm feeling very lucky!
It is good to be good, but way better to be lucky!
Cheap fix-well done!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 02-04-2018   #15
TX '90 ZR1
TX '90 ZR1's Avatar
WOW!!
Glad you caught it in time.
Every time I have wheels off of anything, when I re-install I go around TWICE with a torque wrench. Just to make sure after the first drive I check them again with the torque wrench.
I know some poo-poo the torque wrench. I learned my lesson on a '69 Mach 1. Lost a tire because I thought I knew when the lug nuts were tight enough.
Also, not a bad idea to get the wrench calibrated occasionally.
Kenny
1990 #442
Old 02-04-2018   #16
Originally Posted by TX '90 ZR1 View Post
WOW!!
Will note this!
Old 02-04-2018   #17
Mystic ZR-1
Mystic ZR-1's Avatar
Make sure the bolt holes are still round...
Old 02-07-2018   #18
Flyman 27
Flyman 27's Avatar
You are so lucky, if that wheel had let go it would have done a LOT of damage, plus the wreck....
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 02-11-2018   #19
haber rj
Wow sure am glad that you decided not to drive it. Anyway in the end all is good enjoy your ride.
haber rj is offline   Reply With Quote
Old 02-12-2018   #20
So, I got the car up on stands this morning, ready to manually turn the wheel and see what was going on. The first thing I notice is that the driver rear wheel is loose! OMG, like really loose I could rock it back and forth and 4 lugs came off by hand.
Took the wheel off and turned by hand...no noise. So, I guess the sound was due to the loose wheel?
I'm feeling very lucky! I guess when I swapped the wheels last time I must have missed tightening these lugs down (I was in a bit of a hurry). Oh man.
Thanks all for the feeback
wow to me it sounded like the rear axle hub was bad. Bolt it up and let us know
