01-25-2018 | #11 | |
Re: Fidanza users
01-25-2018 | #12 |
Re: Fidanza users
Yeah Dempsey installed it when he ported the heads and did the cams...
I wouldn't say its a steady noise up until 2,300 rpm.....Its more likes a few seconds up until 2,300.......Noise sounds like a saw cutting....... Demps said its the " usual " single mass flywheel noise........Would be curious to see how other cars reacted to the fidanza.....Drove a 95 for a short distance over a year ago w a fidanza....Don't remember being as noisy as mine though......Mines a 91.... Sent from my LG-TP260 using ZR-1 Net Registry mobile app |
01-25-2018 | #13 | |
Re: Fidanza users
H
01-26-2018 | #14 |
Re: Fidanza users
Dempsey did mine as well as part of the DH350 package. The electric saw sound is a good description. Most noticeable if I touch the gas in 5th or 6th, I have the sound, it immediately stops when I take my foot off the gas. I will follow Paul's advice about resonance and look for something loose or maybe the exhaust touching something.
Thanks, Bill
LT5 Red/Red |
01-26-2018 | #15 | |
Re: Fidanza users
01-26-2018 | #16 | |
Re: Fidanza users
01-27-2018 | #17 | |
Re: Fidanza users
01-27-2018 | #18 |
Re: Fidanza users
Have you inspected the u-joints.... all 6 of them?
01-27-2018 | #19 |
Re: Fidanza users
I have not. I removed the exhaust hangers in the middle and by the differential to see if the exhaust is hitting anything, but that didn't help. Forgive my question, how do I check the U joints? Would they be suspect if the buzzing seems to be RPM related rather than speed related?
Thanks, Bill
LT5 Red/Red Last edited by 9T1 Red ZR1; 01-27-2018 at 03:04 PM. |
01-27-2018 | #20 | |
Re: Fidanza users
Trans in neutral, Rotate the drive/half shaft by hand, back & forth, CW to CCW & look for movement of u-joint in the yokes. Do not confuse with driveline slack which is normal. Best check involves some labor. If in doubt, remove drive shaft. remove caps from rear joint. Dry & dusty = bad. Replace both ft & rear. Same thing with half shafts
