01-10-2018 | #11 |
Re: Alternator rebuild parts??
Did you end up resolving the issue? Just thought Id mention I do have my oem 94 alternator I pulled out for a billet unit 2 years back. was running fine no issues. I did buy a brush from gm and replaced it and put it back together. I was reading into the windings and stuff and just wanted a newer design so I bought the aftermarket one. Thread reminded me I had it
01-10-2018 | #12 |
The rotor came apart. The copper that connects its windings to the base of the slip ring along with some Bakelite was in small pieces. Clinkity clink. I took it to a local rebuilder not knowing what else may have fried with the pieces bouncing around. Probably happened during some 6-7k rpm action. [emoji16] Thanks for the offer.
01-26-2018 | #13 |
Ultima 124 Amp Alternator
The Ultima 124 Amp Alternator - Remanufactured R111799A from O'Reillys fits the 1990 ZR-1 perfectly. This Alternator costs $100. The Ultima is a bit heavier with the body a bit larger in diameter with identical mounting points as the stock Alternator. The Ultima 124 Amp Alternator fits perfectly under the Plenum of the LT5.
See Item #2 Backup Tail Light Switch and Alternators
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-04-2018 at 02:01 AM. |
01-26-2018 | #14 |
Great info. For all. Cost me $100 to have mine rebuilt. But it took two weeks.
01-26-2018 | #15 | |
Your rotor coming apart complicated/delayed yours - that's a somewhat uncommon failure for most CS144. There is such a thing as OVN (Overnight Shipping) that likely would have eliminated the delay. I'm sure you also mentioned 'not rushed' to the fellow also. I'd say you did well!!! I understand the cam sensor R&D is doing well also. |
02-04-2018 | #16 |
I have taken the 1990 #72 ZR-1 with Phil's Improved Fuel Pressure Regulator and the Rebuilt Ultima 124 Amp Alternator on several Quarter Mile Runs and one 100 mile round trip with NO ISSUES. I have yet had to replace any Rebuilt Alternators from O'Reillys
3. Installing All Aluminum Alternator Pulley. Both the bottom and top Alternator Mountings and the threaded hole at rear of Alternator that excepts the bolt from the small angled brace that attaches to the Injector Housing Bolt are ALL identical to the stock Alternator. The Hot wire can be seen just above the rear mounting bolt and is actually better positioned on this Ultima 124 amp alternator than the stock alternator. See All Aluminum Alternator Pulley 4. Minor Modification of Air Horn. The smaller single vacuum port (nipple) on the Air Horn pointing back under TB on 90' (90' only) is for vapor Canister Control and which vacuum line is connected to the Charcoal Vapor Canister control valve under the Drivers Side Headlight (on the 90'). This single Vapor Canister Control vacuum nipple almost touches the Ultima 124 Amp Alternator body and has to be bent just a bit as shown in the second photo. This assures the Alternator is not touching the rubber vacuum connector that fits on the vacuum nipple of the Air Horn.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-20-2018 at 09:21 PM. |
02-26-2018 | #17 |
I hope the OP had better luck than I did with my ALT. I took the damn thing apart and set the disassembled ALT on a self and didn’t get back to it for awhile not can’t remember the order of the spacers,doesn’t help that I’ve got other stray ALT parts thrown in the pile. I’ll have to by an extra ALT,get it apart just to get the order of the spacers right.
02-27-2018 | #18 | |
Look at post 6 in this thread http://www.zr1.net/forum/showthread....ght=alternator
02-27-2018 | #19 | |
