View Poll Results: Did you eliminate your Secondary Throttle Vacuum System? | |||
Yes. | 21 | 55.26% | |
No. | 17 | 44.74% | |
Voters: 38. You may not vote on this poll |
11-19-2017 | #11 |
Re: Did you eliminate your Secondary Throttle Vacuum System?
One of the first things I did with my ZR-1 was to disable the secondaries, using chip mods by Haibeck. I was happy with the results. Simplified the system and the car ran well.
About a year later DIY Tune (aka Megasquirt) asked if they could use my car to try and finish up their MS3-Pro ECU for the LT-5. I said sure! When they found out my secondaries were removed, they asked me if I could add them back in. I did, lent them my car, got it back a month later and it ran great. It was noticeably stronger. I'm sure that is because they had the luxury of running many iterations of tune and were able to reach an optimum tune. They said they found that working secondaries helped the engine run better. I don't remember the details about why they believed that. My memory fails me. Perhaps it was the transition stage (a guess). My hunch is, the computing power available today (compared to the late 1980's) allows them more control over the injectors and butterflies. I'm certainly not knocking the removal of secondaries. I'm just sharing this experience to the thread.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015) MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3 [IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG] |
11-19-2017 | #12 | |
H
11-19-2017 | #13 |
I think your perception of better performance has more to do w a custom tune
than any other factor.
11-19-2017 | #14 | ||
BTW, it's not perception. :-) |
11-19-2017 | #15 |
Question: when you eliminate the secondaries does the engine then have less HP ?
LT5 |
11-19-2017 | #16 | |
This Marc Haibeck Link explains when the secondaries are functional as dependent on engine RPM and Throttle Position when in FULL POWER Mode Marc Haibeck Discussion on Secondary Operation It should be noted that the 1990 ZR-1, 1991-1992 ZR-1 and 1993-1995 ZR-1 have different Secondary Operational limits in regard to RPM and Throttle Position. It should also be noted this only applies when the Full Power Switch is on FULL POWER.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-19-2017 at 04:19 PM. |
11-19-2017 | #17 | |
So perception can be and is reality. I was not implying that you were "imagining" a better running motor. I don't think its any more difficult in modifying the tune using the OEM ECM. There's many more parameters that an OEM needs to address and configure due to emissions, driveabiity, and fuel consumption considerations. Understanding how to use them actually gives you greater control over the tune. Not having used the software for the MS3, I can't comment further on its usability, but I can say that it is not necessary to ship your prom anywhere in order to make changes. There's technology available, pretty inexpensively, that makes tuning on a remote basis a possibility.
11-19-2017 | #18 |
I removed them in 2012 and never looked back. One of the butterfly blades broke ingesting the blade and butterfly screw in the top of piston number #2 wedging it open and bending the intake and exhaust valves... I would not of believed that happening or could happen except this was the second time this had happened as last time one of the blades lost the screw on the other side. I suggest if you are in there. Pull em. the secondary system is prone to vacuum failures and leaks and who drives without the car in full power anyway?
The secondary system has two benefits only. Lower emissions and better fuel economy. What you gain is about 1 second response in throttle time, a valley area free of the secondary system with multiple points of failure and the potential of what happened to me in #2014 NOT happening to you. Go boldly. Debate over. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 11-19-2017 at 07:42 PM. |
11-19-2017 | #19 | |
Well...well.....hmmmm.... I like that feature of Full Power with the switch of a key. That is attractive to guys who like the feature of kicking in another set of injectors and doubling the intake porting with the flip of a key. Very Unique and I just like it. Once you fix vacuum leaks the vacuum leaks do not seem to come back Now Debate over Oh.....yes.....I dropped one of those throttle cable bracket screws into the Injector Housing and had to install a new sleeve and a new piston in one cylinder.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-19-2017 at 07:50 PM. |
11-19-2017 | #20 | |
Sent from my SM-N920V using ZR-1 Net Registry mobile app
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) |
