Old 11-03-2017   #11
Default Re: Zr1Products & Powertorquesystems
I contacted SRP, While I know he has some stuff, he does not have the flywheel bolts anymore
Old 11-03-2017   #12
Ccmano
Appreciate your efforts! It was the longer pressure plate bolts I was looking for.
H
Old 11-03-2017   #13
H
That is what I meant, I asked him for the right bolts, just replied here incorrectly calling them flywheel bolts
either way, he has nothing left
Old 11-03-2017   #14
Ccmano
I figured... thanks Jeff!
H
Old 11-03-2017   #15
ARP most likely made the longer PP bolts for Bob. If correct, ARP will have the drawings on file & could make a run of them. The problem is a common one, ARP will probably require a run of 200 or more & the price will still be high. The cost/bolt will become less as the quantity goes up.
Old 11-03-2017   #16
Ccmano
Very true. Unless some turn up I will likely just go the Haibeck route and use the original bolts with some blue Loctite and be done with it. The car will just be making slightly above stock hp anyway.
H
Old 11-03-2017   #17
jss06c6
Yes, Steve, I had the original DM and PP. Going in is your Fidanza and (ZR-1 Valeo) PP. I am aware that using the original PP bolts is an option as Haibeck does on his installations. I would prefer the slightly longer bolts if I can find them.
H
Ahh, got it!
Old 11-03-2017   #18
Jagdpanzer
Jagdpanzer's Avatar
I have a set of extra length ARPs if you still need them.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-03-2017   #19
Ccmano
Very cool! PM sent....
You are a scholar and a gentleman sir!
Hans
