Old 10-16-2017   #11
jss06c6
Default Re: A question about Bill Bs beam plates.
Originally Posted by Ccmano View Post
Interesting... just checked the instructions included with Bills Beam Plates. No mention of adhesives.
H
Hans,
When I got my trans back from Bill a couple of month ago, he did suggest using 3m Window Weld. You can get it at AutoZone or via web. When I took my C-Beam off to pull the transmission, there was a bit of what appeared to be a gray, hardening adhesive on the mating surfaces of both the tailstock of the transmission and the front of the differential. I elected to center and torque the C-Beam in using the beam plates without using the Window Weld to see if it caused any issues. So far, absolutely no problems. I put mine up on the lift to check and clean underneath, so will keep an eye on the C-Beam to check for any changes.
Steve
Old 10-16-2017   #12
Ccmano
Ccmano's Avatar
Originally Posted by jss06c6 View Post
Hans,
Steve
Thanks Steve, I will probably go the same route. Did you clean the old stuff off or leave it?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 10-16-2017   #13
jss06c6
Cleaned it off.. pretty easy to remove..
Old 10-16-2017   #14
No need to trouble about those jigs. A wood pencil will suffice as material to make the two measuring slugs (jigs).
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
