Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 11-20-2018   #11
32valvZ
32valvZ's Avatar
Default Re: Engine Polish
ICE works very well also
Old 11-22-2018   #12
Crusin
Crusin's Avatar
Thanks for info on cleaning LT 5 engine.
Crusin is offline   Reply With Quote
Old 09-08-2019   #13
SitkaSam
SitkaSam's Avatar
I had a detailer clean my LT5 engine compartment. Somehow he managed to dis-color the engine.
Could I use the toothpaste method-to restore the color?
I would appreciate help from someone that had similar experiences.
1990 ZR-1
1993 ZR-1
2011 ZR-1
1958 Corvette
1947 Cadillac
Denali XL Conversion~ Duramax/Allison
SitkaSam is offline   Reply With Quote
Old 09-09-2019   #14
lfalzarano
The detailer probably used a carnauba wax after polishing it. Real wax doesn’t like extreme heat.
I would use deep crystal paint cleaner to remove the wax or other contaminants from all the painted surfaces. Then apply a good polish product. I would not even use an artificial or carnauba wax over it. Just leave the polish. Depending on how often you clean the car, a microfiber toweling (slightly damp) of the engine will remove any road dust and a final toweling with a dry microfiber towel will brighten the engine finish.
After cleaning your wheels just apply the polish to The shiny surfaces for s high gloss also.
My Z gets 2-3K miles per year. I polish it maybe once a year unless I’m going to an event where people want to view the engine.
Just my opinion of what went wrong and how I would address it.
Old 09-09-2019   #15
SitkaSam
SitkaSam's Avatar
Actually he used Griot's Engine Bay Dressing, and the mist or overspray got on the engine.
It discolored before the engine started.
Anyone have any ideas on this issue?
1990 ZR-1
1993 ZR-1
2011 ZR-1
1958 Corvette
1947 Cadillac
Old 09-09-2019   #16
lfalzarano
Engine Bay dressing is for the hard surfaces in the engine compartment and not to dress up the engine.
This dressing is a surface enhancer and protectant for all materials and finishes inside your engine compartment. Adds satin finish to clean engine bay materials for factory look. Doesn't attract dust, making it easier to clean next time. Not for the engine...
Old 09-09-2019   #17
SitkaSam
SitkaSam's Avatar
I stated that the over sprat or mist got on the engine, he did not apply directly on engine
Will the Arm & Hammer tooth paste work on this?
1990 ZR-1
1993 ZR-1
2011 ZR-1
1958 Corvette
1947 Cadillac
Old 09-10-2019   #18
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Let's not go nuclear immediately.
Try the Meguiars Nex Tech and see if that does it.
Toothpaste is an abrasive, although mild, it will still remove material.
Overspray may have deposited on there as opposed to damaging the finish.
Let's start there, and if it works; Great!
If not, lets go with the least abrasive polish and only go as strong as needed.
Marty
Old 09-10-2019   #19
lfalzarano
Default Engine Polish
I agree with Marty of using the Mequiars NexTech as a final step. I use it on my Z’s exterior, because it doesn’t yellow like carnauba wax. If you can find it, Mequiars Deep Crystal Paint Cleaner, then Mequiars Deep Crystal Polish. I’ve seen them on Amazon and some auto parts stores.
Old 09-11-2019   #20
SitkaSam
SitkaSam's Avatar
Thank you Marty and Lou....Will try Nex Tech and let you know if it works for me.
1990 ZR-1
1993 ZR-1
2011 ZR-1
1958 Corvette
1947 Cadillac
