Old 09-25-2017   #11
Regimof
Default Re: Really high oil temp.
I'm assuming that changing the oil temp sensor is a plug and play deal if it's just right near the filter.
I've already made the decision to get it to haibeck come spring. There are just too many small things that I'm not qualified to diagnose. I want to get it as it should be. He seems to be the expert.
Regimof is offline   Reply With Quote
Old 09-25-2017   #12
BigJohn
BigJohn's Avatar
Have you tried keeping your RPM's up?
Old 09-25-2017   #13
Regimof
Pretty sure that's when the oil temp started to climb
Old 09-26-2017   #14
BigJohn
BigJohn's Avatar
My car does not get intake and cooling air from under the car.
I have larger oil coolers and radiator.
What works for me my not help a stock bodied car.
Old 09-26-2017   #15
Mr.Yuck
Oil will absorb more heat than coolant so if your not overheating your oil should not read hotter. Assuming oil pressure and volume are not an issue. You can take an infrared heat gun and take some basic readings next to the sensor and throughout the system by the cooler and determine if you have a gauge issue a sensor or your oil is actually boiling which I am highly doubtful of. We have a shop in South Milwaukee you're more than welcome to come down and I'll take a look at it for you.
Sent from my 2PS64 using ZR-1 Net Registry mobile app
Mr.Yuck is offline   Reply With Quote
Old 09-26-2017   #16
PhillipsLT5
PhillipsLT5's Avatar
Is there a thermostat of sorts that opens and closes like with engine coolant to allow oil to pass thru cooler, if so this could be a issue, or does oil always run thru cooler
Old 09-26-2017   #17
Jagdpanzer
Jagdpanzer's Avatar
Good point, yes, there is a thermostat valve in the filter housing that controls the oil diverted through the oil cooler once the engine is at running temperature. Refer to the photo Dynomite posted earlier.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-27-2017   #18
Regimof
Ok. So I bought the sensor and found where it goes. I was reading on another form and it was stated that it requires a special wrench to do this? It doesn't seem all that awful to get to if you take that intake tube away. Is this true? Do I need a special wrench? Also it seems as if it will be a message with the oil leaking out. Is it best to just do an oil change along with it?
Old 09-27-2017   #19
Left Click Engine Lubrication System Functional Discussion
Let the Z sit over night so the oil drains back out of the Oil Filter/Oil Filter Adapter. Use a 19mm Deep socket 3/8 inch drive. Or use a 19mm Open End wrench
You can remove the two Oil Cooler Lines from the Oil Filter Adapter for more room as you like
Put a little Permatex on the threads of the New Sender before installing that in the Oil Filter Adapter.
