Old 09-27-2017   #11
KPW
KPW's Avatar
Default Re: Dash Intermittent while driving
Thanks for all the info everyone. I had a brief moment to check on some of the low-hanging fruit today.
Voltage key-off is ~12V, key-on is ~14.2V.
I have a quick disconnect on the negative battery terminal, and I had used it to cut power while I replaced the headlight gear bushings this weekend. When I checked it today, it was about a quarter-to-half turn loose...
Did a few quick checks, and the car seems relatively happy now.
Will have to confirm with a more extended drive, but I may be giving myself the dummy award this time around.
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
Old 09-27-2017   #12
Nothing dumb about having the Battery Disconnect Switch
I have the Battery Disconnect Switch on ALL ZR-1s (Negative Terminal) with easy access barely opening the hood
The Battery Disconnect Switch and Having an Operational Secondary Full Power Switch
Old 09-27-2017   #13
Ccmano
Ccmano's Avatar
It's always the simple things that get you. Even professional technicians have a tendency to jump to conclusions when the simple answer is staring them in the face, don't feel bad.
Btw, 12 volts on a resting battery is on the low side. Should be more like 13 volts. I would have that battery checked anyway.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
