#11 |
![]() Join Date: Dec 2003
Knowing you, luck is not a process component. I have no doubt you've covered all the bases. :-)
#12 |
![]() Join Date: Aug 2006
Beautiful! Looks like that piece was born on top of a LT5.
Is that my old failed regulator reborn? |
#13 |
Yes, that is your old regulator body. Used it for a noble cause.
#14 |
![]() Join Date: May 2007
A thing of beauty, Phil. Well done.
Jim |
#15 |
![]() Join Date: Jul 2007
IF this works out.. it will be a great solution
#16 |
Very steam punk. I like it
#17 |
So Phil, this newer style regulator is set for same FP as the OEM one, correct?
#18 |
![]() Join Date: Sep 2008
Nice work!!!
Marty |
#19 |
#20 | |
I wanted to up the fuel rail pressure to 50 psi for the new motor I'm building so this one is the Delphi FP10016 rated at 350kpa. I will also be testing the Delphi FP10023 you mentioned which is the same body form and rated at 300kpa (43 psi). Will also baseline the the stock regulator to see how they all compare.
