Old 09-18-2017   #11
Regimof
Default Re: 2 fuel pressure regulator in under 30k?
Live and learn...
Dammit. Parts came in today. Should be done tomorrow.
I assume next go round I'll be heading to Chicago
Regimof is offline   Reply With Quote
Old 09-18-2017   #12
Originally Posted by Regimof View Post
Live and learn...
Let's see if they fix it first.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 09-18-2017   #13
Regimof
Good Lord don't jinx m
Old 09-19-2017   #14
I would think that spraying fuel would have been evident long before a mechanic found it. Either by smell or sooner by fire,the cats would pretty much be in line with a fuel stream from above. So greatful I work on my own stuff and don't have to relie on a mechanic.
Old 09-19-2017   #15
Regimof
No smell or fire.
I generally do as much as I can but I don't know enough about plenum removal.
Old 09-19-2017   #16
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
I certainly hope that the replacement of the pressure regulator has a more pronounced improvement than the earlier replaced parts which had none.
The "easter egg hunt" method of parts replacement is always troubling.
I also hope that the regulator was not an egg that was broken while the other eggs were being gathered.
The earlier poster voiced a valid concern that a leaking one would have had distinct and easily noticeable symptoms, not to mention dangerous ones.
On the bright side, it apparently wasn't spark, so fuel is a good next suspect.
Wishing you the best!
Marty
Old 09-20-2017   #17
Regimof
Welp... All is well again. No stutter during acceleration. It's good to have it back. It was almost not fun to drive for a minute.....
Almost.
Fun fact, apparently under the intake, a mouse family elected to try and nest there. They didn't make it. Thankfully no wores were chewed. Not sure what else I can do to keep mice out of that car aside from put it in a bubble.
