Old 07-02-2018   #11
scottskill
Default Re: FS: Fidanza Aluminum flywheel, OEM pressure plate
Can a stock throw out bearing be used as well as stock fly wheel to crank bolts?
Sent from my SM-G955U using ZR-1 Net Registry mobile app
scottskill is offline   Reply With Quote
Old 07-02-2018   #12
5ABI VT
Default Re: FS: Low km INA throwout Bearing, Fidanza Aluminum flywheel, OEM pressure plate
I purchased the arp flywheel bolts from Jerry for the install I can include them with the flywheel I believe they are much better/stronger than oem bolts. And yes oem throwout bearing works as well with this setup.
Old 07-02-2018   #13
OE Dual Mass Flywheel bolts cannot be used with any aftermarket flywheels. They are much too long.
Old 07-02-2018   #14
5ABI VT
Thumbs up Re: FS: Low km INA throwout Bearing, Fidanza Aluminum flywheel, OEM pressure plate
Thanks for clarifying ! Jerry does sell the bolts for the flywheel. Jerry are the arp flywheel bolts reuseable ?
Old 07-04-2018   #15
scottskill
What's your asking price for your clutch and associated hardware?
Old 07-15-2018   #16
Flyman 27
Flyman 27's Avatar
Have you sold the INA throw out bearing?
How much do you want for it?
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 07-19-2018   #17
5ABI VT
The Ina bearing im keeping. I have my 93 with its built LT4 stroker I need to put back together with a blue tag zf6 so ill be using it for that.
Old 07-19-2018   #18
Yes
Old 07-19-2018   #19
Blackbelt
Will you take $300 shipped for the whole set up shipped to 92584?
Blackbelt is offline   Reply With Quote
Old 07-21-2018   #20
5ABI VT
pm inc !
