#11 |
![]() Join Date: May 2009
Thx for the replies, after digging into the situation it appears to be more clutch/coil related. Does anyone know the ohm reading for the coil? And should 12v be the voltage going to the coil to engage? Also if not engage correctly could it be adjusted by adding/ removing shims in the assembly.
#12 | |
![]() Join Date: Dec 2005
Thanks, John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
#13 |
![]() Join Date: Sep 2008
Once you have a working air conditioner, either r12 or r134, please remember to do the following.
START THE DARN CAR AND RUN THE A/C, AT LEAST ONCE A MONTH! Yes, especially during the winter months, when the car is not driven or rarely driven. In the best of systems, the charge will leak out, albeit slowly, through seals that become dry. The seals only become dry because the a/c is not being run regularly. I live where it snows too, but it does not snow every day all winter long. When rain washes away any snow or salt, uncover the car; start it, turn on the a/c, and drive it for 15 minutes. Less will break, leak or fail if you exercise the car regularly. It also does wonders for the driver, especially during the cold winter months. So stop moth-balling the car for the winter, only to leave it sit 5 months with no activity. Those of you in warmer climates have no excuse to not drive it 2-3 times a month, regardless of how busy you are. If you can't do it, hand the keys to your son, daughter, spouse or close friend and ask them to care for it. The entire car will be less problematic if you simply exercise it regularly. Marty |
#14 | |
#15 |
OK.
However, my ZR-1 has less than 20k miles, and has it's original charge. Do as you wish. ![]() Marty |
#16 | |
I just need to get mine fixed. ![]()
