07-24-2017 | #11 |
Re: Newbie; Need help with inherited ZR1
old trick ! They tell you the car needs a fortune in repairs , you really dont want to pay out a bunch , they offer to take it off your hands , nothing major wrong with it . They sell it and make a fortune ! Dont fall for it . I used to go to dealer day car auctions , some dealers would check out a car and if they wanted it , they would disconnect something so it wouldnt start or the ac wouldnt work , no one would bid , they end up with the car !
07-24-2017 | #12 |
Only thing they can tell him is it Knox when started!!!
Going to check it out later this week any tips, other than the obvious.
07-24-2017 | #13 |
Thanks, Steve. Good of you to step up on this. It will be interesting to hear about it. I hope it's something minor.
07-24-2017 | #14 | |
We also have pre-detonation knock..... Might as well get some photos of interior and if Red with Tan Interior Might as well check AC if it is blowing cold air. Radio Speakers Front and Rear Right and Left for sound. CD Player. Take Photos of Engine...... Check for Coolant Leaks. Check for Oil Leaks. Does it Charge (Alternator). Any noise up front? Has Green Coolant been used (the GM stuff)? Vacuum pump cycling on and off (how long off between cycles)? Serpentine Belt condition. Belt Tensioner for Play. Air Filter should be checked (indicates if the Z has been maintained). Is the engine Oil relatively clean and what engine oil has it been running on? (Indicates if the Z has been maintained). Could be a dead Spark Plug, Dead Injector, Bad Plug Wire, vacuum line disconnected. Check for windshield cracks or Delamination? Tire wear? Anything Special (wheels, engine Modifications, Exhaust). Condition of Seats and do seat controls function? Check for dings and chips in exterior paint. Do windows go up and down easily? Any Check Engine Light.....and Any Codes? Transmission noise and ease of shifting (would require you drive the ZR-1). I have found usually there exists several small items in ALL ZR-1s which my typical Top End SOLVES ALL ISSUES.......I Do take a Compression Test on ALL ZR-1s but have NOT found any NOT having nice even compression around 200 - 215 on all eight cylinders. I DO change ALL Fluids (engine, Transmission, Differential, Brake, Clutch, Coolant) as part of Top End Restoration. And I DO make my Typical Modifications during Top End Restorations And.....I DO install a Marc Haibeck Chip in ALL ZR-1s compatible with the Modifications You had to ask
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-24-2017 at 05:18 PM. |
07-24-2017 | #15 |
I missed a shift at redline and double clutched from 2nd mistakenly to 1st. I heard a knock all the time, faint at times but it was there. The flywheel had to be replaced. Hopefully, it's not that.
Get a stethoscope and listen to various parts of the engine including up on a lift is how my mechanic found it. $$$$ Sent from my iPhone using ZR-1 Net Registry
07-24-2017 | #16 |
The knock, if my suspicion is correct, is the chain rattle at startup. They ALL do it.
07-24-2017 | #17 | |
We have Knocks, Squeals, Whistles, Hisses, Clatter, Rattle, Clicks and more descriptive terms |
07-24-2017 | #18 |
Thanks.
My first guess would be miss, plug, wire, coil, injector, The flywheel was replaced at some point in the past could be an issue with it. I will take my scanner not sure if they will allow me to hook it up.
07-24-2017 | #19 |
The value of this forum is reflected in these replies. Folks are always willing to help.
07-24-2017 | #20 | |
Sent from my XT1585 using ZR-1 Net Registry mobile app |
