#11 |
![]() Join Date: Apr 2013
The more I think of fire and brimstone, I swear its just crappy fuel we get now and then from the greedy oil companys. Ethonol plays havoc with my vintage bikes and even tho I do my very best to get non ethonol fuel , sometimes it ends up in our tanks . Ethonol melted all my replacement rubber fuel seals on my vintage bikes carburetors and petcock . I had to reinstall all the original rubber seals which being 40+ years old is able to handle ethonol fuels .
I know the 1995 ZR-1 can handle ethonol tho I wonder if ethonol is the cuprit in creating a bad odour , but perhaps the ethonol is cleaning out a few dirty parts also , hence the exhaust odour on startups ... ![]() Sent from my LG-H831 using ZR-1 Net Registry mobile app |
#12 |
![]() Join Date: Feb 2011
https://m.carsdirect.com/car-mainten...ow-to-fix-them
It is most likely your catalytic converters or the emissions system is hosed up. Sent from my iPhone using ZR-1 Net Registry
#13 |
![]() ![]() ![]() Join Date: May 2007
I was thinking maybe the charcoal purge canister is plugged. Normally that gives you a heavy gas smell at the rear of the car although and not a sulphuric smell
Sent from my iPad using ZR-1 Net Registry
#14 |
![]() Join Date: Aug 2015
Mike,
Struggling a bit with "Sulphur" smell.. it shouldn't be in our gasoline. Diesel yes (older distillations), but gasoline not so much. Is the smell like rotten eggs, which is H2S and toxic as hell? I'm leaning toward your cats as well. Is your AIR system still intact or did you remove it? This was old school emissions stuff to push a dose if air into the exhaust stream until the cats came up to temp. If you're still running OEM manifolds with the cats, maybe the fuel is playing with them a bit? I'm really grasping here. Steve Sent from my XT1585 using ZR-1 Net Registry mobile app |
#15 | |
![]() Join Date: Jun 2013
#16 |
Our Shell hightest gas in Canada most definitely do not have ethonol but while travelling in the states we were not always able to find a gas station with no ethonol ...
#17 |
![]() Join Date: Jun 2015
The Egg smell is Sulphur Dioxide and comes from a catalytic converter that is not functioning properly, in most cases. Could be high fuel pressure overwhelming the cat but I think you would have other symptoms if that was the case. Tough to confirm though as you need to replace the cat(s) to confirm. Is the smell constant?
#18 |
The smell is not constant and it only did it 2 or 3 times on startup over the last month or so .After the car starts and isrunning the smell was only for a few seconds .
#19 | |
#20 | |
