Old 07-17-2017   #11
Default Re: High Engine Temperature in Traffic - my solution.
I will certainly second getting Marc's chip. I had one in both my earlier '93 and my '95. Worked great to control temps. However, there is one thing you should not forget and perhaps check. The C4s are "bottom feeders", meaning they pull air for the radiator up from below the front nose of the car. As a result, they also pick up a lot of sand, dust, debris, leaves, etc. Overtime, the fins in the radiator become plugged. When I first had an overheating problem with the '93, with about 40k miles on it, I had the radiator pulled out and it about 40% clogged. (Marc said he once removed a radiator and got about 20 pounds of sane out of it) Hosed it out to clean all the fins. Then installed Marc's chip and it worked fine ever since. It is often difficult to really see if the radiator is clogged while installed (I know Marc has a way to view much of it) so it seemed best to just remove it when I ran into the problem. The '95 was low miles and was not clogged so I just had Marc install the chip. --bob
Old 07-17-2017   #12
G-Sting
G-Sting's Avatar
Originally Posted by Bruce View Post
Morning all.
John, 118 degrees celsius is 244 fahrenheit so the thermostat is well and truely open! It was an experiment that cost me nothing as I had the stuff sitting around the workshop. I might look at a chip change one day but for the moment, its one of 6 cars sitting in the collection so the cost might not make it viable at this stage as its only driven perhaps once a month.
Greetings Bruce,
Might there be a way of posting some nice ZR-1 pics with that epic New Zealand landscape in the background?
Cheers,
'G'
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Old 07-17-2017   #13
USAF Retired
Try cutting the Radiator Shroud to allow direct cold air flow entering the engine?
USAF Retired is offline   Reply With Quote
Old 07-17-2017   #14
BigJohn
BigJohn's Avatar
No No No!
Let's not start cutting up the car.
Fluid levels up to snuff, clean radiator and still over heating!
