Old 07-11-2017   #11
jss06c6
Default Re: Injector issue with 1990?
Man, it's been a long time since we've seen 98 or 100 octane fuel! Brings back fond memories of big block solid lifter engines at 13:1 compression and a BIG cam!!
I
Have you checked your fuel pressure? It does sound like a fuel issue...
Old 07-11-2017   #12
cp1joel
That is interesting ! I would have assumed the US would be getting higher octane fuel as well. Quite a few years ago 100 octane was available in some locations, but now 98, 95 and 91 are readily available.
I have not checked the fuel pressure, good point indeed.
I did notice when the issue was happening, the oil pressure gauge was dropping to about half way when coming to idle, then moving close to or above the 3/4 mark on the gauge.
I don't recall seeing it fluctuate like this before ( I may be wrong).
I am taking the ZR1 to a mechanic on Friday, getting him to give it a good look over and try and sort some of these issues out. He is well recommend for woking on chevy and high performance engines. Very difficult to find anyone who will touch the LT5 in Aus given the low numbers here.
Will keep you all posted on how it all goes.
cp1joel is offline   Reply With Quote
Old 07-11-2017   #13
BigJohn
BigJohn's Avatar
We have 93 here!
E-85 is 105.
Old 07-11-2017   #14
gtcollins@maxnet.co.nz
Hi All our fuel here in the South Pacific is rated with the ron (Research Octane Number ) where yours is mon
(Motor Octane Number)
So our 98 is about your 91 or 93 when I got my ZR-1 po said he ran it on our 91 I tyred it and the engine detonated so I only run BP 98
Regards Glen Collins
Sent from my SM-G930F using ZR-1 Net Registry mobile app
Old 07-12-2017   #15
Now I realize I am dating myself, but in the early 70s I used to fill up my '68 Hemi Road Runner with Sunoco 260, which was 104 octane. It needed it to run well. Wish they still sold that. --Bob
Old 07-12-2017   #16
BigJohn
BigJohn's Avatar
Local Sunoco has Cam2 racing fuel.
Old 07-12-2017   #17
Rodder
In Europe the octane is rated in RON aswell and US use RON+MON/2 which gives a lower value. In Sweden we have 95,98 and E85. An old car magazine test showed our 98 to equal a US rating 92,5 to 93,25 depending on brand. Today some 98 octan is ethanol free depending on refinery the rest is "said" to be up to 5%.
Thomas
Rodder is offline   Reply With Quote
Old 07-12-2017   #18
Our BP 98 is ethanol is free Mobil isn't
Glen
Old 07-12-2017   #19
George Maz
"Quad-pack"
This module controls injector function on 1990 Z.
George Maz is offline   Reply With Quote
Old 07-13-2017   #20
5ABI VT
Me personally I have been mulling over the fuel pressure regulator of late. Few have changed it, some have posted pics and they didnt look too good inside. I wonder as all of our cars are similar in age if it would be a good idea to replace it. Any records of fuel pumps being replaced?
