#11 |
![]() Join Date: Apr 2007
Yeah, I see why you would have worried with your old plate that they took away.....Bob
#12 |
#13 |
![]() Join Date: Apr 2013
#14 |
![]() Join Date: Jul 2007
#24 @ superbright LEDs. I will say they are not as bright in the side markers, the design of the bulb does not utilize the OEM reflector in the side markers.. Also the front turn/Park bulbs will require a resistor if replaced. I am still working on a solution without resistors as to me, the point of LED is less current, add the resistor and you have more draw again
#15 | |
![]() Join Date: Feb 2007
Every bulb in my '91 is now an LED, except for the front park/turn signals which I have not replaced for the reason Jeff mentioned. I assume a digital flasher (with the ground lead embedded) inserted in the four-way flasher would solve that problem, but I have yet to try it since the four-way flasher is so difficult to access. When I installed Corvette HID's replacement LED tail lights, I had to use an electronic flasher in the signal light flasher (which is much easier to access that the four-way flasher) to allow the signal lights to function properly, but that alone would not prevent the signal lights/flashers from operating erratically when I tried LEDs in the front.
1991 ZR-1 (SN666) - Haibeck 510; 410s, Corsa, SW Headers; Hurst SS; DeWitts Rad; RC Injectors; LEDs throughout; `93 MF Sawblades 2016 Z06 - Stock 1971 Stingray 454 LS5 - Sold |
#16 |
No the flasher will not fix it but will be needed. The problem is the way the side marker and park/turn bulbs are wired
#17 | |
#18 |
![]() I will save you the hassle. The side markers run 12v in both directions. Parking lights off, when turn signal is on the side marker is also on. Parking lights on the voltage travels the opposite way and when the turn signal it on the side maker turns off (opposite). I have not really looked to see what can be done to keep the function the same. Sent from my iPhone using ZR-1 Net Registry
#19 | |
#20 |
This is from an 88, probably the same in later years but maybe not
GM used the filaments of the bulbs to their advantage, if I apply 12v to both sides of the bulb it will be off, but with LEDs that does not work, since the Bulb is basically a short, the new LEDs are not. IF I were to place the LED in the front of my car and remove the front Side marker it will work in both cases I have a 2 relay (per side) solution which might be the best I am going to get. it will change the wiring of the marker light and a ground will need to be added, But it would work. Also in current OEM state, if you put LEDs in the front side marker, they will only with parking lights OR Turn signals, not both ( due to GM Design)
