#11 |
![]() Join Date: Nov 2011
Just dyno'd at 530 CSHP. Pete did the work. My wife is learning to hate it.
The single mass flywheel makes the tranny noisy when sitting still. Sounds like the engine is coming apart. I reduced rotating mass, 15# flywheel, light weight pulleys, plus reground cams. The car is lurchy when moving at an idle, like in stop and go traffic or parking lots. This was a side affect I had not anticipated. |
#12 | |
![]() Join Date: Aug 2006
#13 |
I think if u want the car to idle like stock, but w a bit more power, then go for the ported top end w headers and exhaust. 400rwhp is nothing to laugh at.
#14 | |
![]() Join Date: Aug 2015
Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
#15 |
![]() Join Date: Feb 2007
I too went with Marc H's 510 three years ago and couldn't be happier with the service or the performance; it's a different car for all the right reasons. I retained the dual mass FW to avoid the noise that Steve referred to, but it still made 416hp at the rear wheels (with the DM FW delete, it is about 490 rather than 510 at the crank). I went with 410s which I think complements the top end work and headers well. It's not a cheap upgrade, but well worth it if you intend to keep the car.
1991 ZR-1 (SN666) - Haibeck 510; 410s, Corsa, SW Headers; Hurst SS; DeWitts Rad; RC Injectors; LEDs throughout; `93 MF Sawblades 2016 Z06 - Stock 1971 Stingray 454 LS5 - Sold |
#16 |
![]() Join Date: Apr 2013
Pete blessed mine and I am extremely happy with it!
Dr. Pete "Frankenstein's" Ported and Polish combo Cam retiming & Chip Tune Corsa Exhaust No Cat SW Stainless Long Tube Headers MSD Coils DRM Coil Overs Hurst Shifter ZF Doc Beam Plates Center Force Dual Friction |
#17 | |
![]() Join Date: Feb 2012
I have had a single mass flywheel for twenty one years; it only rattles in neutral with the clutch out. ![]() |
#18 | |
Yes, it only rattles at a standstill with the clutch out. The hp curves are interesting also, when I dyno'd, my curve continues up until redline. When my brother did his mustang, it peaked and then dropped off as the rpm continued. |
#19 | |
#20 |
![]() Join Date: Apr 2007
Can't add much more but to reiterate what others have said. Marc's work is first class and reasonably priced for what you get. Best initial mods for me have been (on both cars) 4.10 gears, Hurst short shifter, headers and Corsa and on the 95, Marc's 510 package. He is now getting very close to 520 at the crank with his stock cams 350 package, if you opt for everything including the lightweight flywheel. For reasons noted above, I went with the stock dual mass to avoid the trans noise and it was fine. Costs about 15 hp on the dyno but frankly I didn't notice it, as it was so much faster than stock. --Bob
